ASEKO pool
is it possible to somehow obtain information (temperature, chlorine, …) from ASEKO technology for swimming pools? It is connected with an Ethernet cable with a connected IP address, but these values can only be used in the ASEKO LIVE application
Hi i have the same problem does anyone have a solution?
not yet, no one even called
Hi now the app is live after i made the request
Hi, super, it is a pity that it is not possible to find out if the filtration is active. because only at that moment are all data relevant. tobje sle dpos problem in aseko live.
Hi contact martin that made the app and he could probably ad it if it is available from the unit. I dont have the filtration connected so then he couldent ad it. He probably needs to borrow your account to validate it.
BIG CHANGES TO ASEKO APPS AND API THAT MIGHT DISABLE THE FUNCTION IN OUR APPS AND CONNECTIONS WITH SMART HOME INTEGRATIONS
Aseko has sent an email saying:
September 10th to 15th, 2024, we will be releasing significant updates to the Aseko POOL Live and Aseko POOL Remote apps. These updates are essential for the continued use of ASEKO applications. Without installing them, the apps will no longer be functional.
Please visit my post and make your comments on this. It would be great to see how many of you that will be affected by this.
Link to the post regarding the Change
