[APP][PRO] Aseko Pool dosing systems
first rough go at it
When does the unit give an alarm? When levels are below required?
The Aseko Pool App can give alarms on both above/below levels for ph/chlorine/temp etc. :slight_smile:
Works very well for me, at least the last 30 minutes. :slight_smile:
what is the margin between giving an alarm, e.g. ph required = 7.5, will it already give an alarm when 7.4 or 7.6? Or is there a tolerance of a few percent?
It gives alarms based on min max thresholds. E.g., ph below 6,9 and above 7,8.
in that case you can use the flows to trigger alarms. measure lt/gt is available for all measured capabilities. The thresholds set in Aseko are not visible in the API.
Aseko 3.0.4 has been moved to live. It uses the Aseko Public API. You need to create an APIkey, when you go to the app settings and configure, it will show how-to. Without the key the devices are not updated.
The app will clean older capabilities and create new ones. Please check your flows for updates etc…
Thank you very much! The app is up and running again, and it was very easy to input API key in the new settings dialog! Much appreciated
Thanks, works great for me! :slight_smile:
Thank you for your help, much appreciated!
Hi @Martin_Verbeek
Thanks for a great app was working flawless until a couple of days ago and now I am getting an ehostunreachable 37.221.116.28:443.
This IP range seems to be related to ASEKO’s API infrastructure. Could It be they have changed the IP addresses for their servers?
No clue to be honest. I will have a check. Could you create a diagnostic report?
Just checked, I am not seeing the unreachable…looks okay
Hey, it works fine now, apparently the Aseko cloud had invalidated my API key.
I have no clue why…Anyway, all good and sorry for sounding the wrong alarm.
