@Elmar can you give the above update a go and see if that works.
Your my hero!
like a charm!
@Elmar nice!
Only thing I did was removing uppercase and spaces from the username
And removing spaces from the password
Seems like that did the trick
@martijnpoppen hello, I’ve added 4 Iphones, 3 work perfectly. My Iphone 13 show the distance from home that is multiplied by 1000. I’ve tried to restart both app and Iphone but it remains the same. Do you have any suggestion? Thanks
@Andrea_Marchisi please send a diagnostic report
here the report: 10B3E9A0
it seems that also the other are not really working. One has moved from a position to home and no update at all.
@Andrea_Marchisi that’s a report for Athom employees.
You can send the report from the app settings.
More - apps - Find My - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
one minute ago, mine is now indicating the correct distance. The other one that as moved, is still in the initial position
@Andrea_Marchisi sorry but i can’t do anything with this info. Please send the report and i’ll have a look
3e29c6d8-979d-4ffc-a2df-98d48c064f81
hello, I’ve uninstalled the app and then reinstalled it, adding the devices again. It seems that now they are regularly updated. So far so good. So thanks for your App and the fast support.
@Andrea_Marchisi great to hear ![]()
New app update (
LIVE: 1.5.14):
TIP:
Read the FAQ → [APP][Pro] Apple Find My - #4 by martijnpoppen
Changelog:
NEW
1. NoneFIXES
1. FIX: fix authentication in some scenarios
2. FIX: sanitize login to prevent uppercase and spaces
3. FIX: error handling in login
@martijnpoppen, @DaanV
Hi
The flow starts when the device is charge for 100% and not when “Device is charging”
is there a update possible ?
@Roy_Van_Bellingen please send a diagnostic report → [APP][Pro] Apple Find My - #3 by martijnpoppen
Not sure why you tag @DaanV though ![]()
@Roy_Van_Bellingen thanks for the report
Can you make sure to attach the charger to your phone and after that send a report ?
@Roy_Van_Bellingen checked the report but i don’t see anything weird. The flowcard should just trigger.
My data are not updatede. only batteri % are updatedet, none of the other date are updatede:
Report: bd539306-2c35-42ae-884f-6b20e87d4337
@Mark_Saxling did you already try a repair?
