This app allows Homey to send a Routeplanner to your favourite messaging app or check the current files in The Netherlands. All instruction ar in Dutch only.
Currently has support for:
Notification after planning route (or ask it with action card later on)
Arrival time, delay, duration and distance Route information
File information
Trigger flow when delay is above x minutes (set in device settings)
Install this app and add ANWB Routerplanner as device. Departure location and arrival location should be entered as GPS coordinates in the device settings. Via GPS-coordinaten.nl you can easily convert your address.
This is really cool!
Since I don’t have one default office location, it would be great if I could be flexible in the location. So instead of having a fixed address/GPS location in the device settings, running a flow with tags instead.
Do you consider this would be feasible?
Because to do so, I can remove it from device settings and create an action card for this. Whether this is ideal I don’t know. You can create multiple devices for now anyway. I’ll give it some thought.
One more thing… Every time I try to open the settings to set my GPS location, the Homey app crashes completely.
Curious whether I’m the only one experiencing this issue.
My reply was about the problem with the homey app crashing when I want to edit the coordinates.
One more thing… Every time I try to open the settings to set my GPS location, the Homey app crashes completely. Curious whether I’m the only one experiencing this issue.
