[APP] Philips Hue - Transform the way you experience light
I had to start using Node Red to manage Home Automation, so I could use the 100+ Hue devices because of this issue :frowning:
To be able to control Homey from Node Red I setup a MQTT Broker, then used the Homey App MQTT Client and the great MQTT Hub.
Because I was using that I played with Zigbee2MQTT, and boy oh boy that made me sooooo happy.
Homey still does the stuff I can’t do yet in NR, Eufy Cams & Vacs, the Zappi and a few other things.
I would have preferred to run all on Homey - it would have been quicker and easier and certainly without having to go through a HUGE learning curve, but I wasn’t willing to replace all my Hue lights and sensors, with something that doesn’t crash Homey and Homey was unwilling to fix the Hue app so forced to look for other solutions.
But, for all the work it took I would not go back, everything is so easy and so powerful.
Without Homey I would never have gotten into flashing Sonoff devices to Tasmota, or Node Red or MQTT and the greatest loss zigbee2MQTT.
So thank you Homey for making me uncomfortable enough to find a better way :slight_smile:
I am running it all on a Mac Mini M1 which also runs TV, DVR, Plex, Music Library etc.
When will Athom stop polling the Hue Bridge and use the real-time API? The delay is really annoying.
Hi guys. I have such problem. I have connected Livarno 2m led strip from Lidl to Philips Hue bridge and using this app to connect it to Homey. My problem is that when I operate it via Homey (change brightness, color, turn on off) the light always blinks brighter/ darker every time :exploding_head: do you also have this with Lidl strip? In Philips Hue app it behaves fine.
Hello everyone,
This is probably a basic question that should have an easy answer, but: how to I add my Hue Bridge to Homey Pro 2023? I’ve installed my Hue Bridge today, added my Hue lamps to the Hue Bridge, and now I want to add the bridge to Homey Pro, so I’ll be able to controle my lamps with Homey as well.
I read online that you have to use the Philips Hue app and then add the bridge, but when adding a device from the list the only options are “movement sensor, dimmer switch, dimmer switch 2, lamp, module, plug, smart button, sync box, tap or tap dial”. I don’t see any option to add the hue bridge. How should I go about this? I hope someone can help.
Did you use the right app?
You should use the philips hue app not the on “without the bridge”
Yes, I’m using the right one. The one that’s just called Philips Hue with the yellow Hue logo. Also, when viewing the app page, the bridge does not show up either as a supported device.
You’re not adding the bridge to Homey, you’re adding the lamps managed by the bridge to Homey. So choose “lamp”.
Thank you Robert. Another, possibly stupid, question. How do I let Homey find my lamps? They are connected to the Hue Bridge. When I go to the Hue app in the Homey app, try to add a lamp, it does not detect lamps. Should the lamps be set in some kind of pairing mode?
EDIT: I think I may know what the problem is. Homey Pro is on my guest network, instead of on my primary network. The Philips Hue is directly connected to the router and is therefore not on my guest network. I should therefore change the WiFi network of the Homey Pro. However, I do not see an option to do so in the app. When looking on the website of Homey, it says the homey should be put in recovery mode by putting it upside down. That, however, does not seem to work and may be a solution for a previous Homey Pro. Do you know how I should change that?
EDIT 2: I see I have to put a pin in the bottom of the Homey Pro, I’ll try that!
EDIT 3: Even though I have an iPhone pin, that looks the same as on the instruction, the Homey won’t go into recovery mode. Is there an alternative?
A longer pin. Most phone pins are too short.
Thanks, I just ordered some needles, hope that works. :slight_smile:
UPDATE: It worked, changed the WiFi network and I could easily add the lights!
I’m on a new Homey Pro and I have a Philips Hue bridge with approx 50 lights connected to them.
I installed the Hue for bridge app.
The first time when I added lights, it found lots of them. They are all successfully added.
But I noticed that it’s not all of them. So I run the add wizard again in the Homey. But homey says no new lights found.
They are properly added in the Hue app. And I know I had this before couple of years ago. No idea how I resolved it then.
Any suggestions? I did a reboot of the bridge and the Homey.
What version Hue Bridge? Probably v2. It might be worth, in Hue phone app, performing a clean. It’s in settings. Each Hue bridge can support up to a maximum of 50 devices so when you say approx. 50…how many? And do you have any other hue devices connected
It’s almost at its max. It’s 55. The max is 63 including devices.
And yes it’s the v2. And somehow the problem resolved itself again. Like last time.
A third reboot of the Hue bridge resolved it. Thanks for helping
According to Philips Hue it’s 50 lights and 12 accessories, so if you have 55 lights somehow, that might be causing trouble. I would suggest a second bridge and divide your stuff. Homey is great in that it can be logged into several bridges at once, unlike the Hue Phone app
is there any possibility to add a bridge from a different network? (in my weekend home)
E.g. via the API, like for Tado…?
Thilo
This was 6 months ago, any update Athom? :slight_smile:
This very likely is never going to be changed.
When do you think Athom will add support for the new contact sensor…?
Nobody knows.
Wondering why development of this app is running behind this much. I would think the integration with Philips Hue is one of the most important ones.
I can’t switch to the ‘non bridge’ version because of the lack of support for the in-wall Dimmer Switch.
