[APP] Nexa App by Athom
Nexa
This discussion is started to centralize all Questions, Answers and Information around Nexa App for 433 MHz devices
Note:
This topic is not actively monitored by Athom. If you have issues with this app, please report it to support@athom.com, mentioning the version of the app + a good description of the issue.
Links:
  • CMR-101
  • ECMR-250
  • EYCR-201
  • EYCR-2300
  • LCMR-1000
  • LGDR-3500
  • LKCT-614
  • LMDT-609 (MIMST-1703, pls. see user-info in post #28)
  • LMLR-710
  • LMST-606
  • WMR-252
  • WMR-3500
Temporary board for inventory devices for developing New Apps for Telldus and Nexa
Known Issues
Known Issues will be posted below.
Be free to ask and discuss anything around these devices here!
Generic 433MHz issues like a limited receive range, unreliable (one-way) communication disturbance from other 433 devices and a sometimes a hanging RF microcontroller in Homey may affect your experience. See the (to be created Troubleshooting RF 433MHz discussion)
App Contributors
The Nexa App is closed (not available on GitHub) but actively maintained by Athom.
Report Bugs for this App to the Developers
  • Please use the Link in the App Store and follow the community guidelines, the more info provided the faster it can be solved.
Forum Discussion
Initial Discussion created by @Dijker with info from the community
Ask any Moderator to add/update/correct this Discussion.
Nexa - Frequently Asked Questions
To be updated (reserved)
Can you please add support for WTE-1 and WTE-2?
My Nexa-devices dissapear (broken link) when Homey reboots, so I need to re-add them and go through all my flows every time I have rebooted Homey.
This is a know issue, we already fixed it in the next Homey Firmware version (it is caused by a “bug” in Homey core)
Please add support for NEYCT-705 and LWST-615.
Is it possible to use any of nexas fire alarms? For example NEXA-101LC?
Is it possible to change sound on lmlr-710 (without using the physical button(
Please add support for IPT-1502
Welcome,
Nexa is an Athom App,
Pleas use the form mentioned here below
  • Request to Add support for NEW Features and NEW Devices
Thought I’d just put this up here in case any other newbies like me wondering about support for nexa mwmr-251.
I was able to add it using the klikaanklikuit app and adding it as an acm-250.
The mwmr 251is a very practical little thing enabling the use of a physical switch as well, both on/off/dim.
Any chance to add 868 MHz devices`? from Nexa fire and security
Please could you add support for Nexa Z-Wave 868,42MHz devices?
Thank you Roy, I did read it and I did put in a request using that form. But I also read somewhere (maby was in linked form) that I could also put out a request on the community forum for the chance that an app developer could pick it up.
Ooops, sorry about that. I didn´t take notice of Athom being the developer of the Nexa app :slight_smile:
Unable to get LRLR-710 doorbell to learn from homey without remote
I have several Nexa Ringclock (LMLR-710) and they have worked nice for a long wile. But they have stopped ringing. I have buttons (LMLT-711) connected to Homey and they send their signal correct. But then the Ring of the bell dosen’t work.
I have 2 of them with the same issue. I have removed them, readded them, have powered them of on. I can add them and they do notify so the connection work. But then they do not ring. Have also of course restarted Homey as well.
Running version 2.00
anyone knows if there is a way to make the Nexa smoke alarm model FS-558RF to work with homey? It goes on 433hz.
Anyone tried LMDT-810 motion detector?
Or MIMST-1703 motion detector?
All my Nexa devices stopped working 22 days ago.
I have of course tried reboot and even unplugging homey, and turned some of the devices off and on again.
I see no errors for the devices in Homey, they are just unresponsive.
Anyone has any ideas?
