For me it works, try to re-add your Netatmo - naturally as stated below, Rainmetter shows only Reason value - I understood you are asking for rest for which you naturally needs external temperature sensor
The rainmeter doesn’t even have a temperature and humidity sensor, so that’s not possible, almost looks like you named the outside sensor (which does have temperature and humidity) as rainmeter
they are both 2 seperate devices in Homey
Maybe a stupid question, but do I need the bridge or can Homey handle it?
And - because I often got this question - maybe it’s an idea for apps, that the first sentence in the description is a declaration, if or if not the vendor specific bridge is needed.
thanks - i’ll give them a try.
@RoyWissenburg - is there any installation/pairing guide?
Today I received my valve but I´m not able to add it to homey.
When I start the “new device” process and authentificate with auth.netatmo.com the homey app keep telling me, that there is no device.
Sounds legit because the valve seems to look for a WiFi/Bridge to connect. (the signal icon appears in the valve)
mhhh … think i need to ask the homey support
@Per_Iveslatt - did you find out anything more about the valves?
I use the weather station with Homey directly. No Netatmo bridge.
The Additional Valves (https://shop.netatmo.com/eur_en/group-3nav-eu.html)
only work with an Thermostat or starter pack with bridge.
See https://netatmostatic.blob.core.windows.net/static/energy_helpchoice/helpchoice_EN.pdf
The Homey App just connects to the Cloud Services API.
Pessence/Welcome, Weather station, and Smart Indoor Air Quality Monitor are complete independent products each connecting with their own base station too your Wifi.
Thanks @Dijker - I wasn’t sure because sometimes you dont need a bridge despite of the information of the specific vendor (netatmo, philips, IKEA).
And thats - in my case - seems to be a worth change of any app description for homey apps.
Every developer should give a info, if or if not - or in the case of netatmo - if only some devices need a bridge. Currently its very confusing due to the lag of information.
I see that only for the bridges that use a common protocol like Zigbee or z-wave.
For systems like this that consist of a base stations with some devices that communicate using a proprietary signal you will imho always need the complete systeem.
I don’t know of much exceptions outside some RF systems using 433 Mhz and specified that way. But maybe it is complex for many users new to so many technique.
For this app I suggest you contact the developer, Athom at their support site to let them know as it is not wait they will see your suggestion here. Who knows they will add it to the app info.
Does anyone know if there is a plan to split up the app into just giving access to the weather station and not my security cameras (presence)? Currently I have to give Homey access to all of it or none of it?
Could I ask for help.
I would like to make a Flow based on Netatmo weather temperature or Co2 change:
When: The CO2-level changed
And: ( Logic - tag ) CO2 is greater than 1000
Then: Some action
Unfortunately this does not work - the circle flow icon in Flow list seems to be like inactive?
Some Idea what is wrong?
Thanks in advance.
M
So when u hit the test button nothing happens?
Flow icons explanation here.
When I hit the test button - flow ask me for “test” CO2 value - If I ad value according to the condition, then everything is OK and the Action is processsed.
It looks like the When does not work.
Then all seems fine to me. Check my post above urs for icon explanation.
And make sure u take the correct tag in the logic card.
Ooooo - thanks - I am stupid - wrong Tag
hello, is the integration of the netatmo alarm planned?
Hello I would like to know if it is possible to activate and deactivate the led projector of the netatmo Presence camera using in a flow homey as action?
Have the same, did you manage to solve it?
I also have some problems with Netatmo Cameras:
I would like to tell my Welcome, that everybody has left the house, when I push a button.
I can see some Netatmo entries in the WHEN section…
…but no entries in the THEN category:
So I could trigger a flow by a camera event but can not change camera settings by a trigger.
Is that intended to be so?
btw: IFTTT can fire a Set home empty action to Netatmo. Is there a way to realize this with IFTTT?
