[APP] Netatmo - Same home, just smarter. (by Athom)
@Doekse Can we get an update from Athom on all of these issues?
Anybody can help me please? I have a weather station netatmo
This is the response from Netatmo support on the issues we have experienced recently.
Homey is a third-party service using our APIs, we are not linked to them or their developments
If the feature correctly works in the native Netatmo apps, you must contact them or their community directly
Have a good day,
Leslie - Community Manager
It reports when needed, not possible to do anything about that.
Check that the WHEN card you are using fron this app trigger like it should wil a “Then write to timeline” card.
I opened a support request for Athom and added two diagnostic reports:
  1. When Homey (cloud in this case) can’t control the smart valves with Error: Nothing to update (Code 406)
  2. After uninstalling and re-installing the Netatmo app test version and Homey can successfully control them again (only for 2 or 3 days in my experience)
I a newer Homey pro client.
My idea is to use a automatically flow that “if rain gauge of netatmo detects that it is raining” turn it off a smart plug for example or pull down the shutters. I have a sengled plug and function the flow but only when reboot netatmo in the setting on homey pro How can i able a periodic update of netatmo data in homey pro?? Thanks
Anybody can help me?
That’s not possible.
Nothing the community can do here I think;
Please write to the app developer, Athom in this case: Support | Homey
Support info is to be found at almost every app page at homey.app store
The update interval of Netatmo devices can take up to 7 minutes, some Devices up to 10 minutes and it’s only updated in Homey if needed.
This was communicated on the old community platform at the time. The time of 7/10 minutes is fix and given by Netatmo.
I have never measured the update interval because all flow cards work so far. I cannot say whether the information about the 7/10 minutes is still current.
I have view that netatmo read the change less than 5 min… Homey script can do that? You can help me?
No. Scripting is nothing for me. ;-). Sorry.
Then a better question to Netatmo support would be: “Are there any recent API changes that are not backwards compatible?” Because if Netatmo changes there API , this could cause the Homey app not to function correctly anymore.
I keep getting the error 406
Talking to some people, to those that it works have thermostat, do those who have valves + thermostat confirm that it works?
Because if so, I give up
Everthing is working with valves and thermostaat (with the app Bitcone/legrand/netatmo)
Only valves don’t work?
I’am not goining to remove my thermostat to test that. That’s a lot of (advanced) flows to de fix :face_with_peeking_eye:
Many thanks
Edo
Sorry guys, I was abroad for a while. I can now change the temperatures via the Homey app. Also I can now gointo the settings on the Homey Web page. Good enough for me.
Thanks yous for al your help, very much appreciated.
Does anyone have any updating netatmo values for the last 2 months?
regards
Filip
Sometimes it helps to simply do Maintenance → Repair.
