can only add airco, dryer washer after adding the token
I had a meeting with the Dutch Netatmo team last week. They’re currently in touch with their French colleagues to follow up on the API status. Keep y’all posted!
I have run some tests on version 5.6.2.
The following things work:
- Set mode to
- Set program to
The following things do not work:
- Set the temperature
Hello Doekse, is there any news about the problem? The problem with error code 406 seems to have been around since at least September 24th. The test version of the Netatmo app v5.6.2 does not solve the problem for me. The alternative app and a backup did not help either. What happens next? Many thanks in advance
I received an email from their Head of Cloud yesterday, and he’s now coordinating with our development team to investigate the issue. It seems we may be reaching the limits of our current cloud bandwidth with Netatmo.
I’ll keep you posted!
I have the same issue.
Haven’t noticed until now as it didn’t need heating in my house before today.
It sucks with the timing in the beginning of the heating season!
The thing is that it report temp settings when changed bij HomeKit and actual temp
Hi all, I have Netatmo weather station with additional interior temperature sensor. I have problem that data from temperature sensors are very old, for example 23 days. Function REPAIR helps so than data’s are refreshed, but after few days the same mistake. Does anybody have idea to solve it ? Thanks
You should read this thread and leard that there are problem With the app
Don’t think the app problem affects the weather station. It works for me and two other friends without problems, data refreshes as it supposed.
Hi everyone, after collaborating with Netatmo, we identified issues related to expired credentials. We’ve released a new test version of the app that should resolve these problems. Please give it a try! ![]()
It could be that you need to repair your devices before they start working again.
Sorry - 5.6.3 (test) still giving 406 on ‘Set the temperature’ - but ‘Set mode to’ is working
Did a repair - but didn’t help ![]()
Same experience as ReimerDK with 5.6.3 (test). Using HP2019. Still code 406 on set temp. Did a repair as well.
Best
Same for me, no issues with the weather station components.
Tested and failed ![]()
Updated to test version 5.6.3
Repaired all units
Restarted HP23
Still error ‘nothing to update (406)’
With the app Bticino/Legrand/Netatmo App voor Homey | Homey is the solution to remove a device and than add again (fix flows, so choose a device to remove with not manny flows).
This is the way for now to refresh the token.
Maby is this also a fix for the Netatmo app from Athom
no succes with 5.6.3 test version even after a repair restarts app en HP23 what @Steven_Bareman discribes also is not working with Legrand/netatmo app
The latest beta doesn’t fix the issue sadly. Repair tried, but didn’t solve it either
Is athom just developing in test? where are the test-cases?
Done a fresh install, but the Netatmo app is crashing immediately after starting it. So basically I’m unable to run it. I have the latest version installed (5.6.3) which was updated just one day ago.
Anyone else having issues. Any suggestions? ![]()
