[APP] Eglo - Light up your world
Without our tireless effort researching the root cause and nagging the firmware development team to create the required update, I do not think we would have been able to actually test a working beta firmware last week. As Homey app developer we have no real influence on the device firmware development speed, I also wish it would be different.
But I guess this is what you get for trying to help :man_shrugging:t2:
The goal is to release the updated firmware in January, but as the last goal was missed by a couple of months we did not share this information yet to not raise false hope.
Thank you. Would be great if we can get this going!!
The remote 2.0 is now working with Homey Pro 2023. Remember to update the remote through the Awox app.
Unfortunately we were on holiday when the update was released, but we have now been able to test it and can confirm that version 2.7.6 indeed resolves the issue with Homey. You will need to re-add it to Homey to ensure the correct configuration is loaded.
Wow, these Eglo lights are an absolute nightmare to set up with anything else than their own app (of which they have two, by the way, conflicting ones)! I tried (factory) resetting one of their LED panels so many times now, using some sadistically designed complex on/off sequence that doesn’t work.
Judging by this experience I thought I was dealing with some cheap Chinese crap, but it appears to be an Austrian brand? I should have stuck with Philips Hue lights. Those simply work.
Eglo app seemed to have uninstalled itself from my Homey out of nowhere causing my bathroom lamps to not work anymore. I can’t seem to re-install the app either.
Anyone else experiencing this same issue?
It was updated in the homey Appstore a couple of hours ago,
I have seen it update on one of my Homey’s
So no issues here,
Also Tested a Re-install and that works. Have you tried closing / restarting your mobile app or Web-Browser to refresh the session and Restarting Homey ?
I have, and it doesn’t seem to do anything.
When trying to click on my lamp it tells me “App unavailable”.
try re-installing it using the Web Interface,
Eglo App for Homey | Homey
Does that work?
No, already tried that :frowning:
This is caused by an issue with the Homey CDN. If you restart your Homey and try to re-install from the store using the link @Dijker provided it should work. If that still doesn’t work please contact Athom to check whether they have another solution available, we as app developer cannot help you with this unfortunately…
For those people, who can’t pair up Eglo Connect-z Remote 2.0 to Homey’s Eglo App, I wrote a quick manual in a corresponding topic. This will save you some time troubleshooting. Unforuntately it doesn’t work out of the box, because of an old firmware on the Remote 2.0 itself.
Does anyone has an White+RGB light? Are they separately controllable from homey? Can I control them separately? Like for example enable only RGB ambient light with out turning on the main light?
I have the Rovito-Z, and while it is possible to control them individually, it isn’t very user friendly. So to control the ring LED you have to click the color icon and then you can set the color for the ring LED and you have to click the white temperature to set the main light. If you want to use the ring for notifications, you need to make sure you select the white temperature and then dim to 0% to turn off the main light but still leave the ring LED turned on. So to Google I have to say “Dim the light to 0%” instead of “Turn off the light”
I have the Rovito-Z
We need Eglo to update the flowcards in the app to affect the different light sources.
RGB and White downlight.
that whould do the work easier
