Hi everyone. It took me some trial and error to pair up Eglo’s Connect Remote 2.0 to Homey, but here’s the process that got it working:
- Install the smartphone app called AwoX HomeControl (don’t get confused, the old AwoX app won’t work, you need exactly this newer app version)
- Start the AwoX app, set the remote in pairing mode with [on] + [blue] simultaneously for 3 seconds – it will blink with red light, pairing activated.
- Connect it to the app, then run Upgrade the firmware (mandatory step, to make it work with Homey).
- It’s important to factory reset the remote with [on] + [colored wheel] for 3 seconds, otherwise it won’t connect to Homey. Remote should blink many times with red LED again.
- Remove device from AwoX HomeControl app.
Set Eglo Remote 2.0 into pairing mode by pressing [on] + [blue] simultaneously for 3 seconds - In Homey’s Eglo app press add device and choose Remote 2.0 - it should show up and pair up.
- … profit! <3
Unfortunately without those actions, the remote won’t connect, as it runs the old firmware and requires to be updated. It’s for good, anyway, as they had quite a few security fixes as well.
Hope this manual helps! Don’t forget to like this post, so it bubbles up in the search.
