You’re right, didn’t noticed this screenshot. Nevertheless, this doesn’t change the fact that both the Aqara Gas Sensor with the Zigbee ID lumi.sensor_gas.acn02 and lumi.sensor_gas.acn03 are currently not supported.
Anyone else having issues with their Aqara devices since a couple of hours back? All my temp-sensors has stopped reporting at the same time.
Have tried to reset and reinstall both devices and the Aqara app but can’t get connection with my devices.
Goodafternoon,
Does the APP support the Aqara Climate Sensor W100?
With regards,
Mark
Via Zigbee, no. Because it’s not listed in the App Store.
But via Thread acc. the Aqara website, without requiring an app. However, with limited functionality.
Thread is only available on Homey Pro (early 2023) and Homey Pro mini.
Hi Robert, is there a solution to this problem yet? After moving and not using them for a year, I’ve reinstalled the sensors and immediately get the full/empty message again. I just read that you indicated this problem is with Aqara, so with the sensor. I find this very strange, since I’ve used the two sensors for over a year without any problems, and this only happened after an update in the past. I want to use them again and buy extras, because I can’t find a good alternative anywhere. I hope this can be resolved, or a workaround. @TedTolboom @robertklep
Would be great with H2 switch (single, double) and dimmer support in app.
Can you install them as H1 versions? And, anyone that has used these (H2) version for controlling Hue lights setting the switches in wireless/decoupled mode?
There is a special topic for selling items here.
Any news on the camera support?:grinning_face:
@TedTolboom support for the Aqara Pet Feeder should be very appreciated :blush:
Will Aqara Presence Multi-Sensor FP300 be supported with Zigbee connection?
I know its possible to connect it via Matter/Thread, but I only have a Zigbee mesh, then I would like to add them via Zigbee.
/Kongedam
Could you please add support for a new device?
The Aqara Climate Sensor W100 (Model: TH-S04D) is pairing via Zigbee to my Homey Pro (2023) but is currently being added as a generic “Zigbee device” because the Model ID is not yet in the app’s supported list.
The device is visible in Developer Tools but does not expose its three buttons for use in Flows.
Here is the essential information from the Zigbee interview:
  • Device Name: Aqara Climate Sensor W100
  • Pairing Protocol: Zigbee (Direct to Homey Pro)
  • Manufacturer Name: Aqara
  • Zigbee Model ID: lumi.sensor_ht.agl001
Adding this Model ID should enable the driver to expose the buttons. Thank you for your continued work on the app
No FP300 yet…
1.14.0
18 nov 2025
Add support for the Presence sensor FP1E (FP1E), Smoke Detector (SD-S01E), Valve Controller T1 (VC-X01D) and Roller Shade Controller T1S (CD-M03D). Add support for Aqara Vibration sensor sensitivity settings.
Version 1.14.0 is released to the app store:
Add support for
  • Presence sensor FP1E (FP1E),
  • Smoke Detector (SD-S01E),
  • Valve Controller T1 (VC-X01D)
  • Roller Shade Controller T1S (CD-M03D)
  • Aqara Vibration sensor sensitivity settings.
Next release (v1.15.0, finalizing now) will add support for the Aqara E26/E27 light bulbs and the GU10 light spots.
Next release (current plan, v1.16.0) will add support for the H2 dimmer and switches.
Followed by (v1.17.0) the Aqara W100 climate sensor, the W500 thermostat and possibly the new W600 radiator valve.
@Maurits, @Kongedam the Aqara FP300 is work in progress.
The FP1E created the foundation to build the driver upon, but the FP300 will have some additional features that I will need to map on top of the homey UI / capabilities. It will be released as soon as possible, in the meantime the FP300 can be used through Matter.
Thanks a lot for the info @TedTolboom ! Appreciate it
@TedTolboom, I noticed that after installing the new version, the settings to configure the vibration sensor (like angle and reporting corrections) are no longer available. There is only one (new) setting for the vibration sensitivity.
I tried repairing the device, but only this new setting remains. I am not sure whether this is as intended, but I assume it is bug.
Excellent @TedTolboom! Looking forward to v1.16.0 with H2 dimmer and switches support!
Thanks for reporting. Found the bug, will push for an update ASAP (this evening).
Not able to add the presence fp1 sensor. Homey adds it as an unk own zigbee device.
