I have scrolling though this post and cannot seem to find a final answer. But i assume i already know as when i tried to pair the device it said it was not recognised still.
The Aqara MCCGQ14LM was this every able to work with Homey ?
My guess & comment, even TED never came to this due to the different priorities…the solution is not easy as it would require to apply different discharge curves according to the environmental conditions, eg. mostly temperature. BUT - whenever you got battery measurements flapping, change the battery, it will be on 30% of capacity.
I woke up with a fully crashed homey and after rebooting this app crashed continuously, therefore handed in a report 42919569-9b98-4f5b-a348-418a10626476
I’m currently using Aqara’s Wireless H1 Knob Switch, and I’ve successfully registered it with Homey. However, I couldn’t find any flow cards related to rotation. Could you explain in detail how to use tags for this? I really want to make full use of this knob switch with Homey.
@robertklep@TedTolboom: already my apologies upfront when I’m repeating this question/ issue. I read the thread back towards december 2023 but get lost a bit.
Using several of Aqara smart Plugs (lumi.plug.maeu01). For some of them the power meassurement is working but most of them not. Updated Homey, perform restart, did an interview without results. Any ideas? Thanks in advance!
Model: Homey Pro (Early 2019)
Version Homey: 12.3.0
Version Aqara: 1.12.1
This is Homey debug, you must provide app Aqara debug and firmware details you find in the device details.
Then it depends if the developer is here and reading all the messages.
We added the T1M light a while ago via Matter, now I see the app officially supports. What would reinstalling now provide that the matter install did not? ie is it worth the reinstall? Thank you
Regarding Aqara T1 door/window sensor (zigbee). I don’t see the log or insights where I could check whether the particular windor or door was opened. It’s only available in the flow I guess.
Any plans to include the insights or at least the log information? It would be beneficial to see if the window or door was opened in the past and when exactly.
I just bought 2 Aqara Door & Windows Sensor T1. I have several of thge older version (without T1) since before. ALl the old ones works perfect. Both the new T1 is included in Homey and it looks correct. But they are not “working”. I do not get any alarms. When I check the developer.homey.app zigbee page I can see how they are connected/mapped through an IKEA outlet. I have also tried to connect the sensors standing directly by Homey to ensure no mesh is needed. Still no difference.
I have also tried to do flows to see if I get any triggers but no.
Could it be that the T1 is not compatible with Homey Pro 2019?
I have the exact same problem with T1 and also the previous generation of Aqara water sensors in HP2019. When they are recently added they do not really push any data to Homey (no battery updates, no water alarm when in water etc.) Those added years ago work totally fine. Please report to Homey support. I have an ongoing ticket there, but the more who report the more likely it is to be prioritized I guess.
I have a lot of Ikea routers, but it also applies when the devices use other outlets as routers according to the developer pages.
@TedTolboom You requested diagnostics from those of us who experience this a while ago. Could you read anything out of those?
