Reported to support
My experience with the T1 sensors is that they are more reliable than the older ones.
I have Ikea bulbs and outlets too, and since I connected the bulbs to the Ikea Gateway (so not to Homey), the older Aqara have a much more reliable connection too.
I read a lot of reports here about Aqara in combination with Ikea bulbs, but not in combination with Ikea outlets…
You can hope and “sigh” what you want, by only assuming things you will get disappointed many times in life ![]()
When I read the info about current Matter supported devices, I can’t discover water leak / flood sensors:
Batteries are supported apparently ![]()
Hello everyone,
Do you know if these devices were on the Aqara team’s integration roadmap?
- P2 Motion and Light Sensor
- Smoke Detector
If yes, do you know when?
Thanks for your reply.
Are there people succesfully using the Aqara Light Sensor T1 (GZCGQ11LM)?
I have two of these, but pairing is extremely hard (if succeeded at all, mostly pairing times out) and if I do succeed in this, the sensor doesn’t update any data.
I tried new batteries and pairing them close to homey, but both did not help.
Any idea anyone?
That is a good question, not when rather IF. I do agree with you, Valve Controller T1, is extremely interesting device due to reason they are very rare to find in general. This one being on ZigBee could be potential fit for this app. I do hope it will be technically feasible and that it will be higher on the priority list however usually this kind of things can take months to get included if they get priority.
I also have high hopes for a Smoke Detector support!![]()
Hi Ronald,
Did you manage to get this Aqara smokedetector working?
If I understood well, the non-Honeywell version of the Aqara smokedetector is not compatible. I didn’t see you follow up on your post.
BR Danny
NB sorry for the 1st try in Dutch
Hi
I have a question
How often can this sensor report lux ?
What interval ?
Thanks for the info ![]()
Hi Ted, we have some Problems with the E1 Thermostates , see also thread
the latest update for the external temperature flowcard change does not work reliable and is randomly reset to internal. Me and another User noticed that: Quote:
update for today, we had a small power blackout in town (which is unusual) but after homey reboots all of my 6 E1 with the external temperature setting “lost” this setting again.
the setup of the devices RAMAIN in external status but it does not work and the error message of the flow card say: “the sensor type for the thermostat is currently set to internal, please change the device setting first” so i have to set it back to internal and afterwards back to external and then it will work again… very annoying
And:
JoeyBE
TedTolboom
Hi
Update as of today. The flow card works perfectly, but when the Homey restarts or there is something that causes a disconnect from the thermostat to the Homey, the setting reverts to internal sensor (setting in Homey stays on external but after an interview of the device Internal comes back on).
So can you add a flow card that makes it possible to change (force) the setting to external?
So when the change temp card fails we can add a change setting command?
Thanks
Hi Danny,
Welcome to the community!
And to answer your question, no it is not recognised yet. Homey has no clue what to do with it, bu does see it is a Zigbee device.
We are depending on volunteers to add it.
Unfortunately I can’t do it myself. (Or at least I never tried…)
So, wait, or … request again?
Or buy another brand, that is already supported.
Greetings
Ronald
How can I help you to include Valve Controller T1?
You are replying here in the topic about tha Aqara Zigbee app…
This is off-topic here and there is a topic for it so I am going to move it there.
