As there is no way to upgrade a Homey Pro. When you outgrow it’s resources (memory & storage for example) the logical solution is to migrate to Homey Self Hosted Server. But rather than relegate your investment in the Pro device to e-waste, it would be really beneficial if you could convert it to a Homey Bridge and continue to take advantage of its excellent radios from SHS to manage your home. This would make Homey a more scalable solution.
You can use HomeyLink, though it does require you to run the Zigbee/Z-Wave/433/IR/BLE apps that you want to use on the Homey Pro. You can keep LAN/Cloud/Tools apps on the SHS in that case.
Yes, I am fully aware of the Homey Link app, and I have already considered that. But as you mention you still have to run all your apps that use the Homey radios on the Homey Pro, so defeats the purpose of my suggestion, as it doesn’t truly improve the scalability of Homey.
Yeah, HomeyLink feels a bit half-baked. Unfortunately Athom have dismissed the idea of turning Pros into Bridges so unless they do a 180-degree turn it won’t happen. That said, Athom has made several “course corrections” over time so who knows.
Maybe if enough people want such functionality they might consider it. That was my hope of posting this suggestion, as it would allow users setups to grow and stay loyal to the Homey ecosystem.
I hear you, but looking at the introduction of all new Homey models, there’s little evidence to be found Athom is even thinking in ways of “upgrading/migrating”, or ways to make Homey models act in multiple configurations.
Homey Bridge is a bit of the exception to that, only it’s not a controller, it’s “just” an antenna-as-extension.
- Homey Cloud: no way to upgrade/migrate to other models
- Homey 2016-2019: at first there wasn’t any migration tool for the Pro 2023; then a number of (forum) users requested it, which made Athom consider it and they published it in the end
- Homey 202x: there’s no migration tool by Athom to Homey SHS (there is a community created tool however)
- I’m pretty sure HomeyLink is published as “the universal glue tool”, to create any configuration you like with multiple Homeys
- -,Downside indeed is you’ll need to install & maintain apps & firmware on all Homey-as-extension models used for Homey SHS & Homey Next-Models
Homey SHS is also presented as DIY Homey for “geeks”, it’s not a successor of the Pro models
It’s most unfortunate they don’t see the value in providing ways for users to scale their set-up as their home automations grow over time. Whether that be migration tools, or ways to re-use existing Homey hardware with SHS or newer and hopefully more powerful models in the future.
There are times I wonder if I bought in to the right ecosystem, having only had my Pro 2026 with Ethernet dongle and Bridge for a short few months, and it’s already starting to struggle. But that’s quite a big investment.
Isn’t that true for all self built home automation, regardless of the platform (I’m of course referring to the YT channel Hibbert Home Tech and every time he mentions HA he says his virginity grew back
Hibbert, of course, gets paid the big bucks by the likes of Athom/Homey to praise their products, and every week he has either found The Next Best Thing, or he’s going back to Home Assistant, or whatever ![]()
I would go a step further. SHS should add support for external antennas. You can compare SHS to Home Assistant, but the later does support external antennas and even sells external antennas who are automatically recognized.
Else SHS is just a good flow engine for Home Assistant or Apple Home and discredits itself as a complete system.
Yes! I also am outgrowing my homey pro 2023 2gb ram! I have a lot self hosted. I just want to migrate to self hosted and use the homey pro as a homey bridge. Why they don’t want to do it is beyond me.
Also maybe (less an issue) the option of thread support for shs for homey pro / bridge is a small blocking factor (you can use a other thread border router).
@Doekse any idea why they don’t want to do this? People want to upgrade to shs but don’t want to put an expensive homey pro in ewast.
Thank you!
Just follow the money… - This way self hosted creates more hardware sales.
For exact the same reason they will never let you use by far superior third party antennas.
I understand not doing thirt party antenas. But not adding a way to use homey pro as a bridge has nothing to do for money. People wil not go to shs and buy a homey pro to use it as a bridge. People wil buy a bridge. People already payed for the pro. Why not support it correctly then? There is really no hardware limitation do it is just a way to reflash / update the firmware to support it.
People already payed for the pro = NO additional revenue
People wil buy a bridge = additional revenue
Because they are two completely different systems. Homey Bridge is a device that was originally intended as a cheap antenna for Homey Cloud. So anyone can buy a Bridge, create a free Homey Cloud instance and pair up to 5 devices immediately without a subscription.
The bridge uses very low-power hardware (it’s just a standard ESP32 inside) so the bridge doesn’t do any processing of commands, it just receives raw Zigbee/Z-Wave/BLE/IR/RF commands from the cloud and simply transmits those via its antennas. Homey Cloud requires a subscription for more than 5 devices, Advanced Flow, Energy tab, Insights and Logic. Homey Cloud is also meant for less tech-savvy users, that’s why Experiments and community apps are not supported. This means that the Pro is way better and more feature-rich (doesn’t require a subscription either). By mentioning that you can use your Homey Pro as a Homey Bridge, it will just confuse users since the Bridge and Pro are two completely different systems.
