I’m a home consumer user. I bought the Bridge to do simple Safe house management, lights, cameras, locks, thermostats and switches and it works very well. If I was looking to move to the Pro are there any migration tools, or can support assist in moving my scenes and flows over so I don’t need to recreate them. I have over 150+ devices to re-provision which makes it very time consuming. Second part of the question, what significant advantages will I have moving to Pro? Thank you for the help
-Karan
There is no migration path between Homey Cloud and Homey Pro, you’ll have to re-add all your devices to, and recreate all your scenes and flows on, a new Homey Pro.
Advantage of Homey Pro is that you have many more apps at your disposal and you’re a bit less dependent on a working Internet connection.
Hi Karan,
Additional advantages:
HomeyScript, Ethernet, (manual) local backups, migrate possibility to an other or new Pro 23,
write/run your own apps, Matter (if you like that), local network connections (like Shelly wifi devices with cloud disabled), oh and the Bridge can be used as (ordinary) Zigbee/Z-Wave router, and as 433MHz/IR satellite > more:
