Appstore stable version: Power by the Hour | Homey
Appstore test version: Power by the Hour | Homey
Power by the Hour
Get data from a Homey power/gas/water meter device, and show the usage / production per hour, per day, per month and per year. Know the monetary value and use dynamic tariffs. Know how much your Always-on appliances are using and safe hundreds of Euros per year!
This app can be used for instance together with the Enelogic and Youless app, the Plugwise Smile P1 app, the BeeClear app, the Solar Power app, the Homewizard app, Tibber pulse, or any other app that has a cumulative Energy Meter (meter_power capability), a Power Meter (measure_power capability) a cumulative Gas Meter (meter_gas capability), or a cumulative Water Meter (meter_water capability).
PBTH summarizer device setup
Add a PBTH device and select if you want to summarize power, gas or water. A list of all compatible source devices is shown. Just select the one you want to add. Note that PBTH allows you to use power meters (Watt) as source device. This is however a fallback method that is less accurate then when using an energy meter (kWh) as source device. During pairing PBTH will automatically select the best available source. In the device settings you can manually switch this. If your device doesn’t show up at all, you can select the VIRTUAL_METER at the bottom of the list.
Using the PBTH Virtual Meter Summarizer
Selecting the virtual meter will allow any app/device that has an energy(kWh)/gas(m3)/water(m3) meter to use PBTH, even when the source app is using non-standard meter capability naming. The meter values must then be send to PBTH via a flow. Note that the meter value for energy must be the total kWh, meaning (consumed_high + consumed_low - returned_high - returned_low).
Setting summarizer meter readings
From the device settings you can enter the meter readings as they were at the beginning of a period (this month, this year). You only need to do this once after adding the PBTH device. The meter values will automatically be updated every hour.
Setting tariff and money values
PBTH can be used with any currency. From the device settings you can set the monetary values of various periods (month, year). You only need to do this once after adding the PBTH device. The money values will automatically be updated every hour based on the tariff you set. If your tariff only changes once once a year it is easiest to do this from the device settings. If your tariff often changes, e.g. during nights and weekends, you can dynamically set the active tariff from a flow. You can use a scheduler app to do this, or use a flow like below example.
Compare usage with a yearly budget
Real-time comparison with a yearly reference gas/electricity/water usage, based on a settable budget. Since in winter you usually use more then in summer, a distribution is applied. Next to a linear (flat) distribution, I implemented the distribution that is used by the Netherlands Government for the 2023 price ceiling (‘prijsplafond’), and a PV-system (solar panels) distribution. See explanation on how the % is calculated here: [APP][Pro] Power by the Hour: Insights per hour, day, month and year - #1109 by Gruijter
Finding out how much your Always-On appliances are using
The Minimum value from your main meter can be used to see how much power your always-on equipment is using (e.g. wifi routers, NAS, TV in stand-by, etc). Every 10 Watt you save on this value will result in a yearly saving of around 90kWh (20 Euro)! Note that if you have solar panels you can only measure this value correctly at night. The best moment is therefore just before sunrise in the morning.
Finding out gas or water leaks
The Minimum value can be used to detect a gas leak or water leak. If the minimum over a 24Hr period is not 0, you have a leak! Note that a leak is only detected this way if the leakage is more then 0.5 liter per minute.
Using Day-Ahead pricing (EU market spot pricing)
If you have a European energy provider that changes its pricing every hour (electricity) or every day (gas), you can use the built-in Day-ahead Pricing driver. Add the pricing device and select the correct Bidding Zone.
From the device settings you can set the taxes and markups your provider is charging on top of the net purchase price. All purchase prices are in EURO, but you can set an exchange rate to any other currency. If you enable ‘Send tariff’ all PBTH power summarize devices will be automatically updated every hour. Use the price_changed flowcard, combined with the average price for the next 8 hours, to save money. E.g. Control the car charging per hour, start the dish-washer at the perfect moment, or even put fridges ‘on pause’ for an hour if that is cost effective.
The electricity pricing information is fetched from ENTSO-E, the European Network of Transmission System Operators for Electricity. https://newtransparency.entsoe.eu/
The TTF Gas spot pricing (EOD and EGSI) is coming from EEX.
The TTF LEBA gas pricing is derived from EasyEnergy as seen here: Actuele Energieprijzen - Bekijk Live Gas- en Stroomtarieven bij NieuweStroom
DONATE
If you like the app, don’t hesitate to DONATE
Energie overzicht maken met Power by the Hour
Generating a automatic name for a variable
Gebruik van warmtepomp loggen
Homey Insights vergelijken
[APP][PRO] YouLess, Enelogic - Belgian and Dutch P1 Smart Meter Reader
Elektrische auto opladen op goedkoopste moment
Boiler aan- en uitzetten op de 4 goedkoopste uren dmv PBTH
Energie tarieven
Power usage at the cheapest part of the day
Possible to identify low and high prices over time?
Homey Energy - total energy consumption
Energieverbruik meten grootverbruikers en inzichtelijk maken
Measure device usage over time
Consumption measurement
Homey energie; zien wat een apparaat over tijd heeft Verbruikt
ANWB Dynamische Energietarieven (adv) Flow maken
Atag Ariston smart boiler
HomeyScript for Wallbox Pulsar plus charger lock/unlock pause/resume
Welke instellingen in Power By The Hour?
Tibber een uur voor de laagste prijs notificatie
Homewizard periodieke meldingen (statistieken)
Zonnepanelen uitlezen via powerplug
Showcase your Dashboard
Welk dynamisch contract met zonnepanelen werkt het beste met Homey Pro (2023)? Zonneplan of Tibber?
[APP][Pro] Homewizard 🧙‍♂️
Michaels Bastelstunde für Gas- und Wasserzähler
Homey Energy | Megathread
Totaal verbruik berekenen vanuit huidig verbruik
See cost of energy used per plug for given time frame
[APP][Pro] Solar Panels - Let the sun power your home
[APP][Pro] SESSY Thuisbatterij (NL)
[HowTo] ⚡️ Introducing Dynamic Electricity Prices - Contract Values to enter
Energie verbruik meten per minuut
Noob Questions about energy monitoring and other Devices/Apps
Homey Energy released
[HowTo]⚡️Nieuw in Homey: dynamische elektriciteitsprijzen - Wat in te vullen
Energie flow maken hoe hebben jullie dit gedaan ? Delen flow
[APP][Pro] Advanced Virtual Device (Device Capabilities App) with Unique Text Status Indicator
⚡️The Homey Energy Dongle is now available
Homey Dongle
Dynamic prices missing
Energie prijzen per kwartier?
De homey energy dongle werkt niet met Landis Gyr E360-3P. Wat is het alternatief?
Getting More Insight from My Power Meters
How to determ current gasflow with energy dongle?
I would like to measure the power consumption of a device over a period of time
Upgrading to Homey Pro 2023/Mini - which hardware makes sense in 2025?
Tibber price level problems
Add possibility to calculate on sold electricity
Smart plugs and electricity cost in €
Understanding energy CSV output and tryingt to calculate energy usage
How to get usefull insights data from Gas usage?
Totalen opgewekte stroom Homey
Futurehome puck rele checking norpool pricing on/off waterboiler
Will new Dynamic Electricity Prices support 15 minutes prices?
[APP][Pro] SMA Energy - My home. My energy. Our climate
SolarEdge Inverter App, hoe te configureren
[APP][Pro] MELCloud & MELCloud Extension - Take control of your heat pump
Solaredge-Automatisierung um Speicher zu laden
[APP][Pro][NL] Homewizard 🧙‍♂️
[APP][Pro] SolarEdge + Growatt TCP modbus
Expand the logic card
Dynamische prijzen van morgen niet zichtbaar in energie tab
CEMM CEDEL Energieverbruik manager
Strømkontroll uten tibber
[APP][Pro] Heating Controller with utility prices
[FeatureRequest] Allow Isnights to show future data
Dynamische energieprijzen laden niet
Get the energy usage for ADAX (Clea WiFi) heaters
Difference between PBTH and actual price
Zonnepanelen salderen wat heeft het me opgeleverd?
Scrape Nordpool?
Vaatwasser op laagste stroomprijs
Power by the Hour keine Preise?
EVCC.io
Power by the Hour (Closed)
Pbth
Shelly Pro 3EM cumulative power consumption
[APP] Frank Energie - Energie against dynamic tarifs
Homewizard P1 dongle
Live graphs of energy consumption or power use of certain devices
Weergeven grafieken per dag etc
Electricity meter - variable prices
How to see total daily power consumption for the house?
Flow voor Homewizard watermeter
[APP] Fibaro - Your home is your castle (by Athom)
Kwh prijzen in Homewizard
Zonneplan dynamisch energiecontract tarieven in Homey PRO?
Fjordkraft pulse
Energy KWH
Eneco EEX Natural Gas Spot - TTF -> Welke selectie in Power by the Hour app van Homey
Smpl mini display: battery powered e-ink display made for Homey
What values do I need to use for Frank Energie Dynamic Energy prices
[App][Pro] Zaptec charging
Smart plug with power monitoring (16A)able to reset measures
Eigen gebruik dynamische modus. Sessy batterij
How can I display Tasmota data?
Komma getal HW watermeter
Grabbing JSON data from 3rd Party API
Ask to making 15-minute peak power available. Comes via P1 port Digital meter to Energy dongle but not to Homey PRO for using in flows
NordPool 15 minute electricity pricing
Homey keynote - 12 October 2022
Youless, Homey & Synology?
Blitzwolf BW-SHP13 energie uitlezing werkt niet?
Wie helpt?
Looking for an app for energy measurement
[Howto] set a value to a virtual device
Energy App
Homey Energy - Dynamic pricing is here (Experimental)
Gebruikte en terug geleverde Energie per Dag, Week, Maand en Jaar Weergeven, hoe?
Unknown power to tag
[APP][PRO] Plugwise Smile P1 - Dutch and Belgian Smart Meter Reader
Homey Pro - Building a system
[APP][Pro] Power by the Hour [Feature Requests]
Energy consumption logs with Aqara Smart Plug
Get info from dynamic number on a web page to use in homey
Flows voor Homewizard P1 meter
2022-01-29
By popular demand, and because of my frustration that Athom is not providing better energy insights, I created this app. It is now still pending approval by Athom in the appstore.
If you want to have insights of your daily/monthly power use, or power production of your solar panels, this app is for you. You can bind it to any Homey device that has a meter_power capability.
Let me know what you think of it.
Nice! Pass it through Athom
Great job Robin, can’t wait to try it!
Super!
This should be done by Athom in the first place…
Thnx man, wonderfull
I’m actually glad an active and committed community developer made this, and not Athom. Now I’m sure questions will be answered, bugs will be fixed and feature requests will be looked at.
But that’s just me.
Athom didnt approve it today. I hope tomorrow…
If you want to give it a go already, you can get it from github
I think that Athom is busy with implementing this app in release 3.1…
4.X you mean (still hoping for the zigbee update announced donkey years ago) :grin:
Thanks @Gruijter saves me about 10 flows of calculating variables which tend to get void when accidentally running the wrong flow :wink:
Was planning to make multiple flows to do exactly this. This is way better. Thanks!
Perfect in combination with Tibber home and pulse, thx! Possible to add year too?
This app will be very useful. Good work!
Maybe Athom should rename their Energy to Power? :slight_smile:
Electricity is measured in Watts and kilowatts
Electricity is measured in units of power called Watts, named to honor James Watt, the inventor of the steam engine. A Watt is the unit of electrical power equal to one ampere under the pressure of one volt.
according to Google.
Energy is power during a time, measured in J, Wh or kWh.
Power is energy per unit of time, measured in J/s, W or kW.
According to me
Electricity is the set of physical phenomena associated with the presence and motion of matter that has a property of electric charge.
According to Wikipedia.
Still not released today. I guess Athom is busy getting the new app store running. Most of my published apps went missing😱
Maybe the are busy with the Zigee rewrite :rofl:
Nu homey chrashes when i use insights. So i am not so happy with it because accidentaly hit the button
Hi Jan_Willem, I’m not sure what you mean. What button makes your Homey crash? Do you mean something the Power by the Hour app is doing? Or something else?
