Meross - Simple Devices, Simplify Your Life.
Hi everyone, this is the central topic for questions/discussing the Meross App. You can use this topic to ask questions and share your experiences with the devices from Meross.
It currently supports all Matter-enabled Meross devices, along with a selection of devices through the node-meross-sdk library. Support for additional devices via the Meross Cloud API (OAuth), including Homey Cloud support, is planned for the future.
Disclaimer: I developed this app in collaboration with the Meross team. It’s a side project I work on in my spare time, alongside my role as Head of Partnerships at Athom.
Supported Devices
Currently supported via Matter
- MOP320 Smart Outdoor Plug
- MRS100 Smart Roller Shutter Timer
- MRS105 Smart Roller Shutter Switch
- MRS200 Smart Roller Shutter Belt Winder
- MS600 Smart Presence Sensor
- MS605 Smart Presence Sensor
- MSH450 Smart Hub
- MSP844 Smart Power Strip (EU)
- MSS115 Smart Plug Mini (US)
- MSS315 Smart Plug Mini (All variants)
- MSS715 Smart Switch
- MSS815 Smart In-Wall Switch
- MTS215 Smart Thermostat
- MTS215B Smart Thermostat
- MTS300 Smart Thermostat
Currently supported via Matter using the MSH450 Smart Hub
- MA151H Smart Smoke Detector,
- MTS150HMA Smart Radiator Thermostat
- MS130H Smart Temperature and Humidity Sensor
Currently supported via MQTT/LAN API
- MSS100 Smart Wi-Fi Plug
- MSS105 Smart Wi-Fi Plug
- MSS110 Smart Wi-Fi Plug Mini
- MSS115 Matter Smart Plug Mini
- MSS120 Smart Wi-Fi Plug
- MSS210 Smart Wi-Fi Plug
- MSS301 Smart Wi-Fi Plug with Energy Monitor
- MSS305 Smart Wi-Fi Plug with Energy Monitor
- MSS310 Smart Wi-Fi Plug with Energy Monitor
- MSS315 Smart Wi-Fi Plug Mini
- MOP320 Smart Wi-Fi Indoor/Outdoor Plug
- MSS620 Smart Wi-Fi Indoor/Outdoor Plug
- MSS630 Smart Wi-Fi Indoor/Outdoor Plug
- MSP843 Smart Fast Charging Power Strip
- MSP844 Smart Fast Charging Power Strip
- MSS420 Smart Wi-Fi Surge Protector
- MSS425 Smart Wi-Fi Surge Protector
- MSS426 Smart Wi-Fi Surge Protector
- PSX340 Smart Wi-Fi Surge Protector
- SP425EW Smart Wi-Fi Surge Protector
- SP425FW Smart Wi-Fi Surge Protector
- MSS510 Smart Wi-Fi Single Pole Switch
- MSS550 Smart Wi-Fi 3-Way Switch
- MSS710 Smart Wi-Fi Switch
- MSS715 Smart Wi-Fi Switch with Energy Monitor
- MSS810 Smart Wi-Fi In-Wall Switch
- MSS815 Smart Wi-Fi In-Wall Switch with Energy Monitor
On which Homey models can this app be used?
Matter-enabled devices are supported on Homey Pro (Early 2023), Homey Pro (2026), Homey Pro mini, and Homey Self-Hosted Server. To connect Matter-over-Thread devices to Homey Self-Hosted Server, a Thread Border Router is required.
Non-Matter devices are supported on all Homey models running firmware v13.0.0 or later.
How can I add a device?
For Matter devices, select the appropriate device from the pairing list and follow the on-screen instructions.
Non-Matter devices are organized into categories, such as Smart Plugs, Smart Switches, and Smart Surge Protectors, just as they are in the Meross mobile app. Select the appropriate category and sign in to your Meross account. All supported devices in that category will then be listed and ready to add.
How does Homey communicate with the Meross devices?
Matter devices communicate using either Matter over Wi-Fi or Matter over Thread, depending on the device.
For non-Matter devices, Meross Cloud is used to sign in and retrieve your device list. Afterward, commands are sent over your local network whenever Homey can reach the device directly. Status updates may still be delivered through the cloud via MQTT.
Check Protocol in the device settings: HTTP means commands are sent locally, while MQTT means they are sent through the cloud..
