Priknr1
February 11, 2019, 8:10pm
1
This app supports most zwave.me devices, including rebranding like Duwi.
https://apps.athom.com/app/me.zwave
Supported Devices
Keyfob
WALLC-S - Scene Switch
WALLC-S V2 - Scene Switch
054336Z - Z-Wave.Me dimmer
054336 - Duwi built-in dimmer
05439 - Schuko plugin dimmer
064394 - Schuko plugin dimmer
05461 - Z-Wave.Me Double Switch
064367 - Düwi Blind Control v1.3
054367Z - Düwi Blind Control v1.3
05431 - Düwi Built-in Switch (ZW ES 1000)
064381_out - Schuko Outdoor plugin Switch
064381 - Schuko plugin Switch
054375 - Schuko plugin Switch
05457 - Z-WAVE.ME Built-in Switch
ZME_05468 - Dimmer Busch-Jaeger duro 2000 (Artic White)
Tomm
July 2, 2019, 9:12am
3
Someone got the correct settings for the ZME_WALLC-S?
Battery keeps draining in about 2/3 weeks.
Current settings:
Blocks wakeup even when wakeup interval is set --> Wake up is blocked
Send unsolicited battery report on Wake Up --> No
Wake up interval active --> No
Wakeup interval (in seconds) --> 15728400 (max.)
@Priknr1 Lately the app crashes almost daily. Is this something that you can look in to?
Hi Patrick,
Can you tell me if the app will be compatible to Homey 5.0 (SDK2)?
please just rename the SDK in the app, it should work again thanks
This request is addressed to the creator of the app, please rename SDk 1 to SDK 2 or 3. thank you
Jamie
July 21, 2020, 3:56pm
9
Thats not really how it works @Ronny_Belllmann
The problem isn’t that you you have not registered your car, the problem is what your trying to drive down the freeway is actually a camel.
Call the camel what ever you like SDK1 or SDK9929 its still just a camel.
In other words: the app needs a rewrite!
legalR
July 28, 2020, 8:52pm
12
Is there a possibility to update the app to an SDK 2 / 3 version, i am using 24 zwave.me devices (dimmers and roller shutters) in my house, and i would also like to update my homey to FW version 5.x in the nearby future.
I have already made an request. Maybe also offer an extra donation for your devices.
https://community.homey.app/t/homey-community-app-requests/2713/394?u=peter_de_vos
I added 2 of my scene buttons WALLC-S but only button 1 single push works. Does anyone know what I might be doing wrong?
@ Tomm: Did you ever figure out the best settings? if so, do you mind sharing?
BTW I can only get button 1 to work. Do you have all 4 buttons working?
Tomm
November 10, 2020, 10:33am
16
All 4 buttons did work but I never found the correct settings for not draining the batteries in a week…
I sold it so I am afraid i can not help you…
Have a wall switch zmee 05434, it is not supported as one of the few from the switches in this range.
As it operates with two wires it is a nice product.
Is it possible to add support for this switch
Did you try to add it as the 05431? Pherhaps this will work. First reset the device before you try to add the device
DRuw
February 11, 2021, 1:06pm
20
Any update on this for the new Homey software? I got a warning this app will be lost…
