Goedemorgen Alle ik heb een zonnescherm van Hornbach en daar zit een Dooya motor in DM45RD-50/12-DL. ik krijg hem niet gekoppeld aan homey, kan iemand mij helpen. b.v.d.
groet Marco
Deze al gevonden? zo ja, wat was je volgende stap?
Goedemiddag J. Pekkeriet.
Ja die had ik al gevonden, maar daar kom ik niet verder mee.
Met vriendelijke groet
Marco
Dooya motors met een 433 signaal kun je waarschijnlijk koppelen met behulp van:
He Tomm,
Dank je hij werkt
Marco
I have an awning with Dooya motor DM45RD-50/12 that i’m trying to find a way to add into Homey, tried the Brel app (not the one mentioned here as my Homey is the 2023+ one and have had no joy.
Anyway to add this, i can add it using the 433mhz app but obviously as it has rolling codes that doesn’t work ![]()
Maybe they use the Somfy protocol? That has rolling-code, there is an Homey-app for it
Marco
Did you use the old Brel app that Tomm linked or the new one? I guess if you use the linked one this was on an older Homey, not the 2023 one?
I’m trying to get the same shade/remote working on the 2023, really struggling.
For the newer Homey models (post 2022) you’ll need this Brel app
https://homey.app/en-us/app/com.brel-home.brel/Brel/
Pair the remote controlled “device”
, and use your original remote in order to learn a signal.
I’ve tried this, go through the motions of adding and it adds a device but when i go to the device and try and open manually using the up/down buttons nothing happens. Could this be a range issue from my Homey to the shade? My remote works fine from what seems like miles away, is the Homey’s range a bit worse and moving it or getting a Homey Pro Mini closer to the shade would work better?
Homey Pro 2016-2019 had a way bigger 433MHz range compared to the Pro 202x models. I’m afraid this also applies to the Pro Mini.
4m w/o obstacles should work. I"d then move it in 1m steps further away and test if the shades still respond, until you’ve found the range limit.
Pro Mini doesn’t have 433Mhz in the first place, it needs a Homey Bridge for that. Probably the Homey Bridge hardware is limited
