Zigbee smart plug dimmer
Does anyone knows a zigbee smart plug that has a dim function?
The sockets I have seen have only on/off function like the Philips Hue, Innr and Osram for example.
I dont think that there is dimmable plug at all because you can plug also devices to plug, that are not dimmable!. If you want to dimm light connected to plug (e.g. night table lamp) you will have to make one for you, or use smart bulb with remote.
Edit: ok, found some dimmable plugs on internet :face_with_hand_over_mouth:. Would like to see how my TV would handle dimming in that.
@Igy Dimmable plugs are normal.
You should try it with the tv. But the manual probably states what they are for. You should read on.
@Igy May I ask you referenes of dimmable plugs you found ?
E.g. here https://www.amazon.com/GE-Wireless-Compatible-Monitoring-45852GE/dp/B019G6RQCS
