For most devices: When a value is changed (more than the minimum step), it sends an update.
The frequency is limited b/c battery life, but a change should be reported within seconds.
It also depends on the brand, model and app, and what users can set
What does the 10 mean when you want a sensitivity of 0.1?
Can you show a screenshot of the device settings?
What’s the brand + model sensor?
(Btw, do you trust Homey + wireless sensors enough with your heating system?)
Searching info on this device : SNZB-02D, I saw that this issue seems very common. The probleme would be due to a bad (partial) initialization while the pairing.
So, I try to repair and during the insertion, I press the button on the device several times.
And now, it is working correctly !
Neverthemore, the minimal increment seems to be 0,2°, even on the device
