Z-wave is not working via Homey Bridge
I have a Homey Pro central device which has two Homey Bridge as extender.
I have many z-wave devicea I want to include to Homey (after removing it from my old z-wave center). The inclusion is not working at all next to any of bridges. I can only include z-wave device with Homey Pro. If the inclusion is done, and put the device to its final location, communication is not working even if the z-wave device is sitting next to Homey Bridge. Getting timeout continously.
Zigbee is working without any problem far from Homey Pro.
I have many z-wave devices cannot be moved close to Homey Pro. I also do not want to move Homey Pro as per I want to closes bridge performs the inclusion.
Any idea for z-wave issue?
Thanks!
Gabor
Are the Bridge and the Homey Pro in range? What does it show in Homey Developer Tools ?
Yes, they are in range. I did not know about developers portal, and it seems z-wave is not appearing one of my bridges. Maybe that could be the problem.
Maybe I need to reset or something similar to make it work.
Thanks!
G
Do the two satellites have Z-Wave connetivity wirh Homey Pro?
Yes, thank you. It seems somsthing went wrong during the 1st onboarding process, because one of bridges did not build up z-wave protocol. It did not have route on developer portal.
After offboarding and onboarding, it solved.
Thanks!
Gabor
FYI and for others,
https://support.homey.app/hc/en-us/articles/7263667137052-Setting-up-Satellite-Mode-for-Homey-Pro
Keep in mind that Homey Bridge is intended to work in a single location, ensuring seamless connectivity within your home. Using it in Satellite Mode won’t extend your Zigbee and Z-Wave networks to another building, even if you are connected to the same Wi-Fi network.
So for everyone: first connect the bridges as satellite in neighborhood of Homey Pro and check the Bridge has joined both the zigbee as the Z-Wave network.
