Osorkon
September 13, 2019, 1:31pm
8
Zumindest glaubt homey das. Gehe auf die 3 Punkte und führe „heal“ aus. Bei Batteriegeräten muss Du diese nach ausführen heal sofort manuell aufwecken.
Siehe hier:
Rx = receive signals.
So homey received that amount of signals from your device, looking at your other devices there is definitely something wrong with your plugs and this happend in a short amount of time, try enabling the log below to see what they send.
If it is COMMAND_CLASS_METER then it is a known issue of the (micro) plugs themselves and you should contact nodon about this, as it is a manufacturing error.
I’ve seen the same with 1 of my micro plugs I have (I have 7 in total).
Tx = tra…
