Yeelights suddenly not working
Since yesterday evening i suddenly have a problem with my Yeelights in the homey app and flows.
Everything was working fine, but yesterday evening my flows did not work and did not switch off my yeelights, after manually trying to switch them off in the homey app, i get the following error:
request to https://open-cn.yeelight.com/api/control/ failed, reason: certificate has expired
I restarted homey, I restarted my router, nothing works, i also tried to install a new device via the yeehlight app with different server (china, europe or us) but i also get “503 Service Unavailable”
I can still control the lights via the official Yeehlight app.
Does anybody have any idea how to solve this?
This is an issue with the Yeelight servers. You’ll either have to wait until they fix their certificate (since it expired two days ago), or perhaps the Yeelight app developer can add an option to their app that will accept expired certificates to.
In either case, you’ll have to wait for this issue to be fixed by someone.
Yes, it’s either an issue with the server or the API endpoint domain changed. You should contact Athom at Support | Homey , since they are the developer of the Yeelight Homey app.
Thanks, already contacted support, let’s see and wait
It’s the same thing here. Did you get a response from support?
No reply, but I solved the problem by using the Yeelight LAN app. Now everything is working fine.
