Just a heads up for anyone that uses the Conexis L1 Door Locks from Yale with the Blue Z-Wave module, it seems Yale don’t want to allow integration with all Smart Home Systems or at least they are not going to make it easy. I currently use this so you can unlock doors using Homey Presence, unlock if smoke detectors go off, reminder to lock if late at night etc. All this is set to change as they plan to phase out the Yale Conexis L1 App by end of July and replace it with the Yale home App.
In their own words “To enable integrations: You must purchase the Yale Access Module and DoorSense PLUS Connect Wi-Fi Bridge (Save 50% on Connect Wi-Fi Bridge. Applies at checkout)” which means you cannot use the Z-Wave module and must rely on their bridge which currently only supports integration with Alexa, Google Home and Apple. Worse still the design means you need a separate Wi-Fi bridge for each lock you have as you cannot have multiple locks on a single bridge, so you have to buy bridges at £70 each plus a new Yale Access module at £5 per lock.
If you want to continue to use the Z-Wave module then the process to add and remove new users/fobs etc. becomes very awkward as follows:
/************** Extract from their web - see link below ******************/
You can still use Z-Wave and not use our module if you wish. However, if you ever wanted to add or remove tags, you could not do this via your app.
This can be done manually however by using the below process. *
*Please be aware that this involves a factory reset, which wipes all credentials and requires setup of the lock, module, and credentials again.
Factory reset the lock with the module removed (Page 29 of Conexis Manual).
Reset the actuator inside the door so that the tail-bar is vertical (see pictures A and B on page 8). Once done, refit the handle and Hand the lock (Page 15).
Scan all of your cards and tags into the lock- when doing this, once you have single pressed the R button- 1 by 1 scan in ALL your Cards/Tags carefully but quickly (you only need to press the R button once to do this). Once you have scanned in all the tags- press R to finish.
Once this is complete, you can reinstall your Z-Wave Module.
I personally think this is a real step backwards not allowing general integration with other Smart Home Systems and forcing users to buy and install multiple hubs.
There doesn’t appear to be any IFTTT support either so probably any automation would have to be via Alexa or Google which is not the most straightforward.
I phoned them to have a chat about this and ask how they expected existing Smart Home systems to work and they are not interested, they just want you to buy their own eco-system and that’s it. I’ll probably look to replace these now with something that allows better control and doesn’t restrict me to their App.
I’m not sure if there are any plans to integrate via Wi-Fi into the current Homey Pro App (Yale Digital Lock App for Homey | Homey) but I’ll ping the developer to see if that is a possibility.
Just a heads up if you are using these types of locks.
Link to the upgrade details
Link to the Z-Wave instructions
