Xiaomi Humidifier 2
I just received and installed a Xiaomi Smartmi Pure Evaporative Air Humidifier 2. I know the token and the IP Address. However, when I add it, I get the following error;
device.power is not a function
I would like to only make it work when my humidity is low. The andriod app doesn’t seem to let you set a humidity level. With Homey I could make it depending on a humidity sensor in my home.
Any idea on how to get this working?
I have the same problem in homey with tj xiaomi humifier 1. and sometimes I have this message " Could not find that PairSession"
I wait an answer like you. please someone!!
Same problem here but with PHILIPS WiFi light bulb by Xiaomi.
Homey does not work with Xiaomi humidifier v2. It gives the error shown in the picture and does not display.
IP and Token are OK.
I can’t get the image here now? The error is “Device is unreachable:”
