Hi!
So first, I wish a Happy New Year to everyone here.
I have the Logic Home Control Z-Wave Coupler for GIRA (ZHC5002) in my house, with the 6-buttons module from GIRA. Basic push button functions are working based on Flows. However I do not get them to work in pair mode for dimming, what needs to be configured with associations, as far as I know. Could anybody help me set this up?
I want the first paddle to be used in pair mode, button 1 should dim down and buttons 2 should dim up the light of the dimmer device with node id 10.
The Z-Wave Coupler has node id 4, button 2 has the device id 2, so the address of the buttons 2 is β4.2β.
In the advanced settings of the Fibaro dimmer module, I found the Z-Wave association parameters where to put the node id in, but I donβt know which group is correct to be filled in, so I put the node id in any of the groups.
However on the side of the Z-Wave Coupler I only find group 7 until 11 for button 2?! Not any group 5 in the setup for button 2, as in the config of the dimmer. Could that be working? Which group does here needed to be configured and how?
And I also do not find any field in the advanced configuration to put the node id (10) of the dimmer in?!
So what do I need to do to make these smart 6-button-switches dim the lights in my living room?
Any help would be great
