I’m still suffering this issue, it works sometimes but there are days when the detection fails. Strange that only me is encountering this problem. Sleep data is correct when looking into withings app.
create a IFTTT fallback, that way you always have a trigger when someone goes in or out of bed.
Most of the time it works fine here, but there’s a lot of delay in some detections.
Same issue with IFTTT.
Sometimes it works flawless and sometimes it doesn’t respond at all.
then the problem is not Homey but withing connection/servers, nothing you can do about that…
Do note that there is NO direct local connection between the mats and Homey, all data/connectivity is via the withing servers, something like:
mats–>local wifi–>internet–>withings servers–>internet–>ifttt(or)athom cloud–>internet–>local wifi–>homey
Hi
Does anyone else have issues with Withings sleep Analyzer? Worked fine for me yesterday morning, but last night and this morning its not working.
Same here
Same for me but Withings do have issue occasionally. Hopefully it will work again soon ![]()
same here, 2 mats stop working since yesterday.
Also IFFTT connection is not working, i can’t even open the app on my mobile phone without crashing.
Have no idea how to fix this..
It would be great if there was a local connection to these mats, they have a BT and WIFI connection, it seems that it should be possible to connect and read them locally (only going in or out bed was enough)
From what I’m reading, it only uses BT to set up WiFi, and after that it only uses WiFi to transmit your data to the cloud (presumably through a secure connection, using client certificates to thwart any MITM attacks).
not sure about that.
When you update the firmware it also goes via BT as changing some settings.
So maybe it is possible to connect to BT and read the status of the mat, just need to know if someone is in or out bed, i do not need any medical/sleep data in Homey ![]()
That’s what I read on the Withings page ![]()
Neither the “Withings Sleep” Mat or “Withings Sleep Analyser” have been working for me since the 8.0.8 update. ( use 8.0.8 as a time reference, it may or may not be related).
Super odd though - the Health app hasn’t updated in 23 days where as homey was working until yesterday.
Interestingly, the Plugwise Anna has also stopped working since “the last update”: Plugwise Anna not connectable
Woonveilig app, also comes up with 500 internal servers error
at the moment the withings mats work normally again…
I started ‘working again’ at 4am when it triggered my lights. ![]()
i received all ‘missed’ notifications/push from IFTTT (using it as backup) and direct yesterday evening.
So the mats did detect when i went out and in bed, but did not report them at that moment, these i received all yesterday evening. Since then it worked ‘normally’ again, i receive direct calls (withings app) and via IFTTT
No issues since yesterday evening.
Has anyone else noticed in the last couple of days that woke up / went to bed has stopped working again?
Last update in homey applet was April 8th, sleep score stilling being updated in the health app. So the devices are working.
But I’m not getting any updates from either the sleep mat or the newer Sleep Analyser with in homey.
Thermo, bmp connect and scales all working correctly.
Same problems here. I have two Withings sleep analyzer and after installing in homey they work for one or two days, then they stop working. I tried to install them new, but after a short time I have the same problem. I use HP2023. Is it possible, to see what homey does?
Tom
