What color temperatures do the predefined values represent and how to get kelvin values?
I have been trying to look this up in the documentation etc. but I can’t really find a good answer. What color temperatures do those values represent? I can see that the right one, at 3 o’clock, sets the value to 0.75 but I still have no clue what color temperature that actually represents. And I’m not even sure if it’s consistent between products (meaning if 0.75 is the same temperature in kelvin across different devices).
From what I understand from the Homey code, it uses a range of 2500K to 6500K, where a value of 1 represents 2500K and 0 represents 6500K. So 0.75 would be 3500K.
From reading through the code of the Zigbee driver it seems like the 0-1 value just maps to the max supported range of the device. So 0.75 on a device that supports 200-450 mired will look vastly different then on a device that supports 300-450 mired. Which really is too bad if you want your lights set to the same color temperature. And setting something like a precise 2700k is almost impossible without manual calculations.
