Connection to WiFi, but error.
Restarted multiple times, but same error.
I meant, you wrote a statement, so I thanked you for sharing.
When you want to ask something, just ask with what you’d like some support with?
Rmb
September 30, 2023, 11:16pm
5
That’s in the title of this thread
You’re absolutely right hahaha
I obviously don’t read titles very often
@Audun_Heimdal while you don´t give any detail about your wifi setup, I’ll just shoot I guess?
Do you have separate 2.4 and 5GHz SSID’s? When no, try to create separate networks for both frequency bands, and / or
When you have a wifi mesh system with several AP’s,
it is probably hopping between two (or more) AP’s very often;
try to let Homey use a fixed AP, by using MAC address filtering, or Band Steering, and/or lower the transmit power on distant AP’s.
Have it on 2,4 g yes. No mesh
Obvious probably, but did cutting the power from the bridge, for 5 minutes, make any difference?
Is the wifi router 2.4GHz modus set to b/g/n, or g/n?
Try setting it to b/g to see if it makes a difference:
This post covers the Homey bridge as well:
Make sure your WiFi is using the 2.4 GHz network.
Make sure your WiFi uses the b / g standard, only n or ac does not work.
Turn off your Homey.
Restart your Router and any Access Points that distribute IP addresses.
Start your Homey again.
If the above do not work, turn off 5 GHz WiFi and support for n and ac in your Router / Access Point during Homey installation.
Ensure that your SSID (the name of your WiFi) does not use characters other than numbers and letters - do not us…
