Virtual thermostat does not calculate measured temperature correctly
I am using Homey Heating Scheduler version 2.0.7 on a Homey Pro 2026.
My virtual thermostat, “Plan Temperatuur Schedule”, is linked to two Aqara W600 thermostats:
  • Kitchen: measured temperature 18.0 °C
  • Bay window: measured temperature 18.5 °C
Both temperature readings arrive correctly in Heating Scheduler, but the virtual thermostat displays approximately 12.2 °C instead of the expected average of 18.25 °C.
Changing the virtual thermostat’s target temperature also results in a “Timeout after 10000ms” error.
I have restarted the app several times without success. The problem persists.
Could you help determine why the virtual thermostat is not updating or calculating its measured temperature correctly?
Kind regards
You could use the Advanced Virtual Devices from the Device Capabilities app :wink:
