Hi
I would like to create a virtual device thermostat and link it to one of my evohome thermostats.
The first part I manage, but how to link such a virtual device to a specific thermostat? Obviously that are already created as device based on the Honeywell app.
With the following flow attempt I get an error: invalid capability. Whereby I try to map both values of the thermostat (current temp and set temp) to the virtual device.
https://homey.app/f/9E3O9C/
Thanks.
The first temperature should not be the temperature tag, but the text: measure_temperature
Hi, Thanks for the advice. Error message is now solved.
Now I have this flow: Shared Flow | Homey
Interesting though is that this results in the following values:
But this is not what the Honeywell device is showing:
Current temp seems to be ok. But how to get the target temp correct?
In principle the device can show two data point, but I only manage to feed it one with this flow ![]()
Same procedure, use: target_temperature
Thanks, I was thinking that you need to deal with that one card. Duplicating it for the target_temp works.
One thing leads to another: now I see on the icon of the virtual device only the target temp being displayed. Can this be extended so that it shows both?
