Easily control the temperature of your thermostats.
How does this work and what can it do on Homey?
This app controls the target temperature if your thermostats based on (many) heating plans . A heating plan is list of set points. At each set point, the associated target temperature is applied to a list devices.
A heating plan can be associated with either zones or devices. If a heating plan is associated with a zone, the heating plan is associated with all themorstats inside that zone. Child zones are not evaluated (yet).
Mobile friendly Configuration page allows easy editing. Plans and setpoints can be copied, configuration can be ex-/imported, overview of current set temperatures, …
Full flexibility Heating plans can be associated with zones or devices, in any combination.
Different szenarios for the same thermostats? Heating plans can be enabled and disabled, which allows flexible szenarios triggered by flow (see below).
Not at home? Homey heating scheduler supports different modes and associated exceptions: Automatic, One day at home, One day away, Sleeping, On holiday.
Manual control Each plan can be added as a virtual thermostat device to Homey. This allows to manually override the temperature per “zone.”
Flow integration Set mode, enable/disable plan, apply plan, etc.
Optimal resouce management Your Homey is only utilized when there is something to do: No permanent polling or reading of temperatures in the background. The app only wakes up on setpoints.
Not what you expect? Than it’s probably not what I do at home. Feel free to add a feature request on GitHub.
Hi, I’ve just started to try this out. though I’m not working with thermostats, I’m using a fibaro motion sensor for temp and fibaro wall plug for turning panels on/off. worked great in fibaro HC2 but now I’m trying to replicate this with Athom. is this supposed to work for this app?
The first would translate as ‘activate heating schedule’ the other as ‘apply heating schedule’. I have difficulty to see the difference and the way it can be used.
I donno why, but it seems that from firmware 7.1.4, heating scheduler app is not setting temperature correctly. I didn’t changed anything in app configuration and I have all schedules same, but form unknown reasons some thermostats fail to get correct target_temperature when it’s time.
Restart of application usually helps and it sets temperature correctly - but currently it seems like I’ll need to restart app several times a day…
I have several zones with HeatIt thermostats for electric under floor heating as well as Popp trvs for radiators.
Heating schedules are set with only the HeatIt thermostats selected as devices and no zones selected, but the radiator trvs are adopting the HeatIt set temperature controlled by heating schedules.
Please help. How do I pair a Sonoff thermometer SNZB-02 with a virtual thermostat to control the direct heater. It doesn’t show me the current room temperature correctly.
Just in case someone else has the same bug with homey heating scheduler these days…
(I have already open a ticket at athom)
Every few hours (~5-10 ?), my homey heating scheduler app crashes.
I have upgraded my homey pro (2019) to the latest version 8.1.2 recently.
From this upgrade, every few hours (~5-10 ?), my homey heating scheduler app crashes.
symptoms :
The app is seen as in pause in the app list
When going in the app configuration, i have an error page instead of the normal config page (type error… undefined is not a function, near “a map”. see screen captures)
The flows using the app cards are flagged and the cars designed as ‘not available’
The error is not seen by system (card “an app failed”) => no way to get any alert or restart it automatically.
If I restart the app all seems solved for some time, so i’ll restart it every 6 hours till bug solved.
I don’t have any issues and I’m on the same version of firmware like you are…so it must be something else. Maybe try to backup and restore config of Heating scheduler in the settings.
I’m using the heating scheduler app to control the set points on my heating thermostats.
I also have a hot water heater that wants to be run on a scheduler. This is different because there isn’t a readable thermostat - it’s just got a fixed point (60 degrees c), and I have a zwave relay which switches it on and off.
Is there value to using the heating scheduler app to control the water heating relay?
Can I make it work without a thermostat? If I use a VTherm device how would I configure it? There isn’t a readable set point.
Not sure if with this app, but some time ago I have switched to Advanced Scheduler App for Homey | Homey and this isn’t dependent on the Thermostat.
More over it allows more use cases, eg. tracking different schedules for different things, eg. heating, high/low electricity tariffs and many more.
Your relay must be configured as a heating device in the room where you have also a temperature sensor.
You create a vthermo in this room, it should get the current temperature, and automatically pilot the heater.
