Hamster
1
I have a variable called “TVProgramStartTime”, which holds the time a TV show starts (in a string format hh:mm)
I would like to use that variable to start a flow (to turn on my TV), but when I use the “Date & Time”, I can only select a time manually.
How can I use my variable for the time?
As far as i know this not possible. Variables with time do not work
Morgan
3
If you want easy changeable start time I suggest to try Alarm. An alarm that starts a flow is silent.
Hamster
4
Using an Alarm sounds great, but how do I edit an existing Alarm so it will use my “TVProgramStartTime” variable?
Looking at the Alarm options, I can only “Enable” or “Disable” alarms, but I can’t find anything to set an alarm to my variable.
Found the solution in this post:
