I am working on the Qubino 3-phase meter. Athom started with the app but did not finish the app.
The frustrating thing is that I had the app working but with the migration to the Athom Qubino app it stopt working. The values won’t update.
I am getting the following messages in the log. Does anybody has an idea what goes wrong?
[2020-03-04T14:47:24.702Z] Node[56]: Received application command for COMMAND_CLASS_CRC_16_ENCAP, data: 0x01600d01013202a13cffffffc1000000c8a1
[2020-03-04T14:47:24.703Z] Node[56]: [COMMAND_CLASS_CRC_16_ENCAP] {“Command Class (Raw)”:{“type”:“Buffer”,“data”:[96]},“Command Class”:96,“Command (Raw)”:{“type”:“Buffer”,“data”:[13]},“Command”:13,“Data”:{“type”:“Buffer”,“data”:[1,1,50,2,161,60,255,255,255,193,0,0,0]},“Checksum (Raw)”:{“type”:“Buffer”,“data”:[200,161]},“Checksum”:51361}
[2020-03-04T14:47:24.712Z] Node[56]: Decapsulated frame from COMMAND_CLASS_CRC_16_ENCAP to COMMAND_CLASS_MULTI_CHANNEL, data 0x0d01013202a13cffffffc1000000
[2020-03-04T14:47:24.713Z] Node[56]: [COMMAND_CLASS_MULTI_CHANNEL] {“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[1]},“Properties1”:{“Source End Point”:1,“Res”:false},“Properties2 (Raw)”:{“type”:“Buffer”,“data”:[1]},“Properties2”:{“Destination End Point”:1,“Bit address”:false},“Command Class (Raw)”:{“type”:“Buffer”,“data”:[50]},“Command Class”:50,“Command (Raw)”:{“type”:“Buffer”,“data”:[2]},“Command”:2,“Parameter”:{“type”:“Buffer”,“data”:[161,60,255,255,255,193,0,0,0]}}
[2020-03-04T14:47:24.723Z] Node[56]: Decapsulated frame from COMMAND_CLASS_MULTI_CHANNEL to COMMAND_CLASS_METER, data 0x02a13cffffffc1000000
[2020-03-04T14:47:25.047Z] Node[56]: Received application command for COMMAND_CLASS_CRC_16_ENCAP, data: 0x01600d01013202a19400000d8a00004e03
[2020-03-04T14:47:25.048Z] Node[56]: [COMMAND_CLASS_CRC_16_ENCAP] {“Command Class (Raw)”:{“type”:“Buffer”,“data”:[96]},“Command Class”:96,“Command (Raw)”:{“type”:“Buffer”,“data”:[13]},“Command”:13,“Data”:{“type”:“Buffer”,“data”:[1,1,50,2,161,148,0,0,13,138,0,0]},“Checksum (Raw)”:{“type”:“Buffer”,“data”:[78,3]},“Checksum”:19971}
[2020-03-04T14:47:25.057Z] Node[56]: Decapsulated frame from COMMAND_CLASS_CRC_16_ENCAP to COMMAND_CLASS_MULTI_CHANNEL, data 0x0d01013202a19400000d8a0000
[2020-03-04T14:47:25.058Z] Node[56]: [COMMAND_CLASS_MULTI_CHANNEL] {“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[1]},“Properties1”:{“Source End Point”:1,“Res”:false},“Properties2 (Raw)”:{“type”:“Buffer”,“data”:[1]},“Properties2”:{“Destination End Point”:1,“Bit address”:false},“Command Class (Raw)”:{“type”:“Buffer”,“data”:[50]},“Command Class”:50,“Command (Raw)”:{“type”:“Buffer”,“data”:[2]},“Command”:2,“Parameter”:{“type”:“Buffer”,“data”:[161,148,0,0,13,138,0,0]}}
[2020-03-04T14:47:25.068Z] Node[56]: Decapsulated frame from COMMAND_CLASS_MULTI_CHANNEL to COMMAND_CLASS_METER, data 0x02a19400000d8a0000
[2020-03-04T14:47:25.071Z] Node[56]: Received application command for COMMAND_CLASS_CRC_16_ENCAP, data: 0x01600d02013202a1240000093200002447
[2020-03-04T14:47:25.071Z] Node[56]: [COMMAND_CLASS_CRC_16_ENCAP] {“Command Class (Raw)”:{“type”:“Buffer”,“data”:[96]},“Command Class”:96,“Command (Raw)”:{“type”:“Buffer”,“data”:[13]},“Command”:13,“Data”:{“type”:“Buffer”,“data”:[2,1,50,2,161,36,0,0,9,50,0,0]},“Checksum (Raw)”:{“type”:“Buffer”,“data”:[36,71]},“Checksum”:9287}
[2020-03-04T14:47:25.081Z] Node[56]: Decapsulated frame from COMMAND_CLASS_CRC_16_ENCAP to COMMAND_CLASS_MULTI_CHANNEL, data 0x0d02013202a124000009320000
[2020-03-04T14:47:25.082Z] Node[56]: [COMMAND_CLASS_MULTI_CHANNEL] {“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[2]},“Properties1”:{“Source End Point”:2,“Res”:false},“Properties2 (Raw)”:{“type”:“Buffer”,“data”:[1]},“Properties2”:{“Destination End Point”:1,“Bit address”:false},“Command Class (Raw)”:{“type”:“Buffer”,“data”:[50]},“Command Class”:50,“Command (Raw)”:{“type”:“Buffer”,“data”:[2]},“Command”:2,“Parameter”:{“type”:“Buffer”,“data”:[161,36,0,0,9,50,0,0]}}
[2020-03-04T14:47:25.091Z] Node[56]: Decapsulated frame from COMMAND_CLASS_MULTI_CHANNEL to COMMAND_CLASS_METER, data 0x02a124000009320000
[2020-03-04T14:47:25.331Z] Node[56]: Received application command for COMMAND_CLASS_CRC_16_ENCAP, data: 0x01600d02013202a16c0000002a000073b3
[2020-03-04T14:47:25.333Z] Node[56]: [COMMAND_CLASS_CRC_16_ENCAP] {“Command Class (Raw)”:{“type”:“Buffer”,“data”:[96]},“Command Class”:96,“Command (Raw)”:{“type”:“Buffer”,“data”:[13]},“Command”:13,“Data”:{“type”:“Buffer”,“data”:[2,1,50,2,161,108,0,0,0,42,0,0]},“Checksum (Raw)”:{“type”:“Buffer”,“data”:[115,179]},“Checksum”:29619}
[2020-03-04T14:47:25.342Z] Node[56]: Decapsulated frame from COMMAND_CLASS_CRC_16_ENCAP to COMMAND_CLASS_MULTI_CHANNEL, data 0x0d02013202a16c0000002a0000
[2020-03-04T14:47:25.343Z] Node[56]: [COMMAND_CLASS_MULTI_CHANNEL] {“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[2]},“Properties1”:{“Source End Point”:2,“Res”:false},“Properties2 (Raw)”:{“type”:“Buffer”,“data”:[1]},“Properties2”:{“Destination End Point”:1,“Bit address”:false},“Command Class (Raw)”:{“type”:“Buffer”,“data”:[50]},“Command Class”:50,“Command (Raw)”:{“type”:“Buffer”,“data”:[2]},“Command”:2,“Parameter”:{“type”:“Buffer”,“data”:[161,108,0,0,0,42,0,0]}}
[2020-03-04T14:47:25.352Z] Node[56]: Decapsulated frame from COMMAND_CLASS_MULTI_CHANNEL to COMMAND_CLASS_METER, data 0x02a16c0000002a0000
[2020-03-04T14:47:25.358Z] Node[56]: Received application command for COMMAND_CLASS_CRC_16_ENCAP, data: 0x01600d02013202a16c0000002a000073b3
[2020-03-04T14:47:25.358Z] Node[56]: [COMMAND_CLASS_CRC_16_ENCAP] {“Command Class (Raw)”:{“type”:“Buffer”,“data”:[96]},“Command Class”:96,“Command (Raw)”:{“type”:“Buffer”,“data”:[13]},“Command”:13,“Data”:{“type”:“Buffer”,“data”:[2,1,50,2,161,108,0,0,0,42,0,0]},“Checksum (Raw)”:{“type”:“Buffer”,“data”:[115,179]},“Checksum”:29619}
[2020-03-04T14:47:25.368Z] Node[56]: Decapsulated frame from COMMAND_CLASS_CRC_16_ENCAP to COMMAND_CLASS_MULTI_CHANNEL, data 0x0d02013202a16c0000002a0000
[2020-03-04T14:47:25.369Z] Node[56]: [COMMAND_CLASS_MULTI_CHANNEL] {“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[2]},“Properties1”:{“Source End Point”:2,“Res”:false},“Properties2 (Raw)”:{“type”:“Buffer”,“data”:[1]},“Properties2”:{“Destination End Point”:1,“Bit address”:false},“Command Class (Raw)”:{“type”:“Buffer”,“data”:[50]},“Command Class”:50,“Command (Raw)”:{“type”:“Buffer”,“data”:[2]},“Command”:2,“Parameter”:{“type”:“Buffer”,“data”:[161,108,0,0,0,42,0,0]}}
[2020-03-04T14:47:25.379Z] Node[56]: Decapsulated frame from COMMAND_CLASS_MULTI_CHANNEL to COMMAND_CLASS_METER, data 0x02a16c0000002a0000
[2020-03-04T14:47:25.382Z] Node[56]: Received application command for COMMAND_CLASS_CRC_16_ENCAP, data: 0x01600d02013202a13cffffffc10000000704
[2020-03-04T14:47:25.382Z] Node[56]: [COMMAND_CLASS_CRC_16_ENCAP] {“Command Class (Raw)”:{“type”:“Buffer”,“data”:[96]},“Command Class”:96,“Command (Raw)”:{“type”:“Buffer”,“data”:[13]},“Command”:13,“Data”:{“type”:“Buffer”,“data”:[2,1,50,2,161,60,255,255,255,193,0,0,0]},“Checksum (Raw)”:{“type”:“Buffer”,“data”:[7,4]},“Checksum”:1796}
[2020-03-04T14:47:25.395Z] Node[56]: Decapsulated frame from COMMAND_CLASS_CRC_16_ENCAP to COMMAND_CLASS_MULTI_CHANNEL, data 0x0d02013202a13cffffffc1000000
[2020-03-04T14:47:25.395Z] Node[56]: [COMMAND_CLASS_MULTI_CHANNEL] {“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[2]},“Properties1”:{“Source End Point”:2,“Res”:false},“Properties2 (Raw)”:{“type”:“Buffer”,“data”:[1]},“Properties2”:{“Destination End Point”:1,“Bit address”:false},“Command Class (Raw)”:{“type”:“Buffer”,“data”:[50]},“Command Class”:50,“Command (Raw)”:{“type”:“Buffer”,“data”:[2]},“Command”:2,“Parameter”:{“type”:“Buffer”,“data”:[161,60,255,255,255,193,0,0,0]}}
[2020-03-04T14:47:25.405Z] Node[56]: Decapsulated frame from COMMAND_CLASS_MULTI_CHANNEL to COMMAND_CLASS_METER, data 0x02a13cffffffc1000000
[2020-03-04T14:47:25.643Z] Node[56]: Received application command for COMMAND_CLASS_CRC_16_ENCAP, data: 0x01600d02013202a19400000d9600007d9e
[2020-03-04T14:47:25.644Z] Node[56]: [COMMAND_CLASS_CRC_16_ENCAP] {“Command Class (Raw)”:{“type”:“Buffer”,“data”:[96]},“Command Class”:96,“Command (Raw)”:{“type”:“Buffer”,“data”:[13]},“Command”:13,“Data”:{“type”:“Buffer”,“data”:[2,1,50,2,161,148,0,0,13,150,0,0]},“Checksum (Raw)”:{“type”:“Buffer”,“data”:[125,158]},“Checksum”:32158}
[2020-03-04T14:47:25.654Z] Node[56]: Decapsulated frame from COMMAND_CLASS_CRC_16_ENCAP to COMMAND_CLASS_MULTI_CHANNEL, data 0x0d02013202a19400000d960000
[2020-03-04T14:47:25.655Z] Node[56]: [COMMAND_CLASS_MULTI_CHANNEL] {“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[2]},“Properties1”:{“Source End Point”:2,“Res”:false},“Properties2 (Raw)”:{“type”:“Buffer”,“data”:[1]},“Properties2”:{“Destination End Point”:1,“Bit address”:false},“Command Class (Raw)”:{“type”:“Buffer”,“data”:[50]},“Command Class”:50,“Command (Raw)”:{“type”:“Buffer”,“data”:[2]},“Command”:2,“Parameter”:{“type”:“Buffer”,“data”:[161,148,0,0,13,150,0,0]}}
[2020-03-04T14:47:25.664Z] Node[56]: Decapsulated frame from COMMAND_CLASS_MULTI_CHANNEL to COMMAND_CLASS_METER, data 0x02a19400000d960000
[2020-03-04T14:47:25.713Z] Node[56]: Received application command for COMMAND_CLASS_CRC_16_ENCAP, data: 0x01600d03013202a1240000091500002464
[2020-03-04T14:47:25.714Z] Node[56]: [COMMAND_CLASS_CRC_16_ENCAP] {“Command Class (Raw)”:{“type”:“Buffer”,“data”:[96]},“Command Class”:96,“Command (Raw)”:{“type”:“Buffer”,“data”:[13]},“Command”:13,“Data”:{“type”:“Buffer”,“data”:[3,1,50,2,161,36,0,0,9,21,0,0]},“Checksum (Raw)”:{“type”:“Buffer”,“data”:[36,100]},“Checksum”:9316}
[2020-03-04T14:47:25.723Z] Node[56]: Decapsulated frame from COMMAND_CLASS_CRC_16_ENCAP to COMMAND_CLASS_MULTI_CHANNEL, data 0x0d03013202a124000009150000
[2020-03-04T14:47:25.724Z] Node[56]: [COMMAND_CLASS_MULTI_CHANNEL] {“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[3]},“Properties1”:{“Source End Point”:3,“Res”:false},“Properties2 (Raw)”:{“type”:“Buffer”,“data”:[1]},“Properties2”:{“Destination End Point”:1,“Bit address”:false},“Command Class (Raw)”:{“type”:“Buffer”,“data”:[50]},“Command Class”:50,“Command (Raw)”:{“type”:“Buffer”,“data”:[2]},“Command”:2,“Parameter”:{“type”:“Buffer”,“data”:[161,36,0,0,9,21,0,0]}}
[2020-03-04T14:47:25.734Z] Node[56]: Decapsulated frame from COMMAND_CLASS_MULTI_CHANNEL to COMMAND_CLASS_METER, data 0x02a124000009150000
[2020-03-04T14:47:25.997Z] Node[56]: Received application command for COMMAND_CLASS_CRC_16_ENCAP, data: 0x01600d03013202a16c00000000000031c1
[2020-03-04T14:47:25.998Z] Node[56]: [COMMAND_CLASS_CRC_16_ENCAP] {“Command Class (Raw)”:{“type”:“Buffer”,“data”:[96]},“Command Class”:96,“Command (Raw)”:{“type”:“Buffer”,“data”:[13]},“Command”:13,“Data”:{“type”:“Buffer”,“data”:[3,1,50,2,161,108,0,0,0,0,0,0]},“Checksum (Raw)”:{“type”:“Buffer”,“data”:[49,193]},“Checksum”:12737}
[2020-03-04T14:47:26.008Z] Node[56]: Decapsulated frame from COMMAND_CLASS_CRC_16_ENCAP to COMMAND_CLASS_MULTI_CHANNEL, data 0x0d03013202a16c000000000000
[2020-03-04T14:47:26.009Z] Node[56]: [COMMAND_CLASS_MULTI_CHANNEL] {“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[3]},“Properties1”:{“Source End Point”:3,“Res”:false},“Properties2 (Raw)”:{“type”:“Buffer”,“data”:[1]},“Properties2”:{“Destination End Point”:1,“Bit address”:false},“Command Class (Raw)”:{“type”:“Buffer”,“data”:[50]},“Command Class”:50,“Command (Raw)”:{“type”:“Buffer”,“data”:[2]},“Command”:2,“Parameter”:{“type”:“Buffer”,“data”:[161,108,0,0,0,0,0,0]}}
[2020-03-04T14:47:26.021Z] Node[56]: Decapsulated frame from COMMAND_CLASS_MULTI_CHANNEL to COMMAND_CLASS_METER, data 0x02a16c000000000000
[2020-03-04T14:47:26.049Z] Node[56]: Received application command for COMMAND_CLASS_CRC_16_ENCAP, data: 0x01600d03013202a13c000000000000002c16
[2020-03-04T14:47:26.050Z] Node[56]: [COMMAND_CLASS_CRC_16_ENCAP] {“Command Class (Raw)”:{“type”:“Buffer”,“data”:[96]},“Command Class”:96,“Command (Raw)”:{“type”:“Buffer”,“data”:[13]},“Command”:13,“Data”:{“type”:“Buffer”,“data”:[3,1,50,2,161,60,0,0,0,0,0,0,0]},“Checksum (Raw)”:{“type”:“Buffer”,“data”:[44,22]},“Checksum”:11286}
[2020-03-04T14:47:26.069Z] Node[56]: Decapsulated frame from COMMAND_CLASS_CRC_16_ENCAP to COMMAND_CLASS_MULTI_CHANNEL, data 0x0d03013202a13c00000000000000
[2020-03-04T14:47:26.069Z] Node[56]: [COMMAND_CLASS_MULTI_CHANNEL] {“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[3]},“Properties1”:{“Source End Point”:3,“Res”:false},“Properties2 (Raw)”:{“type”:“Buffer”,“data”:[1]},“Properties2”:{“Destination End Point”:1,“Bit address”:false},“Command Class (Raw)”:{“type”:“Buffer”,“data”:[50]},“Command Class”:50,“Command (Raw)”:{“type”:“Buffer”,“data”:[2]},“Command”:2,“Parameter”:{“type”:“Buffer”,“data”:[161,60,0,0,0,0,0,0,0]}}
[2020-03-04T14:47:26.089Z] Node[56]: Decapsulated frame from COMMAND_CLASS_MULTI_CHANNEL to COMMAND_CLASS_METER, data 0x02a13c00000000000000
[2020-03-04T14:47:26.333Z] Node[56]: Received application command for COMMAND_CLASS_CRC_16_ENCAP, data: 0x01600d03013202a194000027100000a8f4
[2020-03-04T14:47:26.334Z] Node[56]: [COMMAND_CLASS_CRC_16_ENCAP] {“Command Class (Raw)”:{“type”:“Buffer”,“data”:[96]},“Command Class”:96,“Command (Raw)”:{“type”:“Buffer”,“data”:[13]},“Command”:13,“Data”:{“type”:“Buffer”,“data”:[3,1,50,2,161,148,0,0,39,16,0,0]},“Checksum (Raw)”:{“type”:“Buffer”,“data”:[168,244]},“Checksum”:43252}
[2020-03-04T14:47:26.349Z] Node[56]: Decapsulated frame from COMMAND_CLASS_CRC_16_ENCAP to COMMAND_CLASS_MULTI_CHANNEL, data 0x0d03013202a194000027100000
[2020-03-04T14:47:26.350Z] Node[56]: [COMMAND_CLASS_MULTI_CHANNEL] {“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[3]},“Properties1”:{“Source End Point”:3,“Res”:false},“Properties2 (Raw)”:{“type”:“Buffer”,“data”:[1]},“Properties2”:{“Destination End Point”:1,“Bit address”:false},“Command Class (Raw)”:{“type”:“Buffer”,“data”:[50]},“Command Class”:50,“Command (Raw)”:{“type”:“Buffer”,“data”:[2]},“Command”:2,“Parameter”:{“type”:“Buffer”,“data”:[161,148,0,0,39,16,0,0]}}
[2020-03-04T14:47:26.360Z] Node[56]: Decapsulated frame from COMMAND_CLASS_MULTI_CHANNEL to COMMAND_CLASS_METER, data 0x02a194000027100000
[2020-03-04T14:47:26.386Z] Node[56]: Received application command for COMMAND_CLASS_CRC_16_ENCAP, data: 0x01600d04013202a124000009240000deba
[2020-03-04T14:47:26.387Z] Node[56]: [COMMAND_CLASS_CRC_16_ENCAP] {“Command Class (Raw)”:{“type”:“Buffer”,“data”:[96]},“Command Class”:96,“Command (Raw)”:{“type”:“Buffer”,“data”:[13]},“Command”:13,“Data”:{“type”:“Buffer”,“data”:[4,1,50,2,161,36,0,0,9,36,0,0]},“Checksum (Raw)”:{“type”:“Buffer”,“data”:[222,186]},“Checksum”:57018}
[2020-03-04T14:47:26.396Z] Node[56]: Decapsulated frame from COMMAND_CLASS_CRC_16_ENCAP to COMMAND_CLASS_MULTI_CHANNEL, data 0x0d04013202a124000009240000
[2020-03-04T14:47:26.397Z] Node[56]: [COMMAND_CLASS_MULTI_CHANNEL] {“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[4]},“Properties1”:{“Source End Point”:4,“Res”:false},“Properties2 (Raw)”:{“type”:“Buffer”,“data”:[1]},“Properties2”:{“Destination End Point”:1,“Bit address”:false},“Command Class (Raw)”:{“type”:“Buffer”,“data”:[50]},“Command Class”:50,“Command (Raw)”:{“type”:“Buffer”,“data”:[2]},“Command”:2,“Parameter”:{“type”:“Buffer”,“data”:[161,36,0,0,9,36,0,0]}}
[2020-03-04T14:47:26.407Z] Node[56]: Decapsulated frame from COMMAND_CLASS_MULTI_CHANNEL to COMMAND_CLASS_METER, data 0x02a124000009240000
[2020-03-04T14:47:26.670Z] Node[56]: Received application command for COMMAND_CLASS_CRC_16_ENCAP, data: 0x01600d04013202a16c000000000000398a
[2020-03-04T14:47:26.671Z] Node[56]: [COMMAND_CLASS_CRC_16_ENCAP] {“Command Class (Raw)”:{“type”:“Buffer”,“data”:[96]},“Command Class”:96,“Command (Raw)”:{“type”:“Buffer”,“data”:[13]},“Command”:13,“Data”:{“type”:“Buffer”,“data”:[4,1,50,2,161,108,0,0,0,0,0,0]},“Checksum (Raw)”:{“type”:“Buffer”,“data”:[57,138]},“Checksum”:14730}
[2020-03-04T14:47:26.681Z] Node[56]: Decapsulated frame from COMMAND_CLASS_CRC_16_ENCAP to COMMAND_CLASS_MULTI_CHANNEL, data 0x0d04013202a16c000000000000
[2020-03-04T14:47:26.682Z] Node[56]: [COMMAND_CLASS_MULTI_CHANNEL] {“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[4]},“Properties1”:{“Source End Point”:4,“Res”:false},“Properties2 (Raw)”:{“type”:“Buffer”,“data”:[1]},“Properties2”:{“Destination End Point”:1,“Bit address”:false},“Command Class (Raw)”:{“type”:“Buffer”,“data”:[50]},“Command Class”:50,“Command (Raw)”:{“type”:“Buffer”,“data”:[2]},“Command”:2,“Parameter”:{“type”:“Buffer”,“data”:[161,108,0,0,0,0,0,0]}}
[2020-03-04T14:47:26.691Z] Node[56]: Decapsulated frame from COMMAND_CLASS_MULTI_CHANNEL to COMMAND_CLASS_METER, data 0x02a16c000000000000
[2020-03-04T14:47:26.767Z] Node[56]: Received application command for COMMAND_CLASS_CRC_16_ENCAP, data: 0x01600d04013202a13c00000000000000e61e
[2020-03-04T14:47:26.768Z] Node[56]: [COMMAND_CLASS_CRC_16_ENCAP] {“Command Class (Raw)”:{“type”:“Buffer”,“data”:[96]},“Command Class”:96,“Command (Raw)”:{“type”:“Buffer”,“data”:[13]},“Command”:13,“Data”:{“type”:“Buffer”,“data”:[4,1,50,2,161,60,0,0,0,0,0,0,0]},“Checksum (Raw)”:{“type”:“Buffer”,“data”:[230,30]},“Checksum”:58910}
[2020-03-04T14:47:26.778Z] Node[56]: Decapsulated frame from COMMAND_CLASS_CRC_16_ENCAP to COMMAND_CLASS_MULTI_CHANNEL, data 0x0d04013202a13c00000000000000
[2020-03-04T14:47:26.779Z] Node[56]: [COMMAND_CLASS_MULTI_CHANNEL] {“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[4]},“Properties1”:{“Source End Point”:4,“Res”:false},“Properties2 (Raw)”:{“type”:“Buffer”,“data”:[1]},“Properties2”:{“Destination End Point”:1,“Bit address”:false},“Command Class (Raw)”:{“type”:“Buffer”,“data”:[50]},“Command Class”:50,“Command (Raw)”:{“type”:“Buffer”,“data”:[2]},“Command”:2,“Parameter”:{“type”:“Buffer”,“data”:[161,60,0,0,0,0,0,0,0]}}
[2020-03-04T14:47:26.788Z] Node[56]: Decapsulated frame from COMMAND_CLASS_MULTI_CHANNEL to COMMAND_CLASS_METER, data 0x02a13c00000000000000
[2020-03-04T14:47:30.448Z] Node[56]: Received application command for COMMAND_CLASS_CRC_16_ENCAP, data: 0x01600d04013202a194000027100000a0bf
[2020-03-04T14:47:30.449Z] Node[56]: [COMMAND_CLASS_CRC_16_ENCAP] {“Command Class (Raw)”:{“type”:“Buffer”,“data”:[96]},“Command Class”:96,“Command (Raw)”:{“type”:“Buffer”,“data”:[13]},“Command”:13,“Data”:{“type”:“Buffer”,“data”:[4,1,50,2,161,148,0,0,39,16,0,0]},“Checksum (Raw)”:{“type”:“Buffer”,“data”:[160,191]},“Checksum”:41151}
[2020-03-04T14:47:30.458Z] Node[56]: Decapsulated frame from COMMAND_CLASS_CRC_16_ENCAP to COMMAND_CLASS_MULTI_CHANNEL, data 0x0d04013202a194000027100000
[2020-03-04T14:47:30.459Z] Node[56]: [COMMAND_CLASS_MULTI_CHANNEL] {“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[4]},“Properties1”:{“Source End Point”:4,“Res”:false},“Properties2 (Raw)”:{“type”:“Buffer”,“data”:[1]},“Properties2”:{“Destination End Point”:1,“Bit address”:false},“Command Class (Raw)”:{“type”:“Buffer”,“data”:[50]},“Command Class”:50,“Command (Raw)”:{“type”:“Buffer”,“data”:[2]},“Command”:2,“Parameter”:{“type”:“Buffer”,“data”:[161,148,0,0,39,16,0,0]}}
[2020-03-04T14:47:30.469Z] Node[56]: Decapsulated frame from COMMAND_CLASS_MULTI_CHANNEL to COMMAND_CLASS_METER, data 0x02a194000027100000
