I’m also having this problem hassio/broadlink/homey -did you get it working?
I only managed to get it work on wall switches via
HA>Homey>Broadlink.
Just cannot figure out how to get virtual switch or button from Homey to trigger HA send command.
I havent played around with compounds yet but sensors and binary sensors works great.
Its also available on HCS.
Will have a look at it. Will be great if virtual device from HA can be detected by homey. Since it does not work now for opposite. Lol
By the way what is HCS? Sorry very noob on this
This app is great indeed! It lacks support for blinds, but you can work around it by creating scenes in HA and adding them to Homey, with virtual devices and some flows you can create something which works.
Hi Everyone! New to Home Assistant and trying to reveal a few devices from Homey that are not supported due to my lack of hardware
I’ve already got a MQTT broker as I’m using Zigbee2MQTT on home assistant, and I don’t want to set all this up separately in a NAS.
I’ve followed the steps in the first post (thanks to @Peter_Kawa for pointing me here) but I’m a little stuck - my devices all seem to have come through (great!) but, they ALL seem to have come through - I now have 90 odd devices in MQTT showing in HA
I went into the devices tab and unselected the majority of them, but they all still seem to be there. Is there any way to ‘refresh’ so that they aren’t all there?
Thx. I’m afraid you’ll need to remove the devices yourself in HA, if you unselected a number of devices in MQTT hub after you already broadcasted them
Ah ****
Don’t suppose there is any way to do that programatically? Remove anything with Manufacturer for example?
Oh wow - that’s way quicker than going into each device!
I know it’s been years since you’ve posted this, but THANK YOU!
I’ve spent days trying to figure this out.
A big Thank you to you too, and @RoelG !
While I was curious what you tried to figure out, I read Roel’s proposed settings and applied them, and surprise, my random unresponsive Homey devices on HA keep working a lot better, there’s almost no unresponsive MQTT devices any longer! Also HA reboots much less.
Hey,
is this thread still alive?
My HA connects to HomeyMQTT and configuration is ok but MQTT in HA doesn’t find any devices or entities.
Do I need to put something in configuration.yaml?
I thought HA would automatically find devices.
/Niklas
Not much info here…
When
HA loads your Homey devices.
So probably there is something not ok.
Did you install MQTT Client as well?
Where is MQTT Broker running, on Homey or HA?
What does MQTT Explorer show?
Sorry for the lack of info, I don’t know why but now it works… Will never more touch it. ![]()
Oh haha, okay then. Enjoy ![]()
I have added devices in my Homey Pro but MQTT in HA doesn’t pick up them.
I have broadcasted from MQTT hub in Homey.
In HA I have tried to restart, reload the MQTT integration.
Any ideas?
What I did, is download the portable app MQTT-Explorer. This will help you to see what the broker receives and what it sends out. Also there you can try manual the commands to see if a device or your flow reacts to topics. For me this has been a big help in debugging.
