Triggering a flow from iphone shortcuts
I wanted to trigger a Homey flow from an iphone shortcut, but when I select “start homey flow”, it doesn’t let me pick whicih flow to start. Instead it asks me which one to start when the shortcut is ran and doesn’t remember selection for future runs.
I’m using the latest version of the Homey app and running ios 18.4.1
Maybe this helps: No available flows in iOS widget - #13 by SunBeech
You should be able to select all manually startable flows in the Apple Shortcuts app.
Flows that are not manually startable (so, which don’t have a blue play button in an Advanced Flow, or the ‘This flow is started’ WHEN card in a Standard Flow) are not available in Apple Shortcuts.
Thank you, in my case I wanted to build an automation, and from that screen there is no way to select a homey flow. So instead I built a shortcut and ran that shortcut from the automation instead of trying to run the homey flow directly.
