During my Homey Pro 2023 set up I opted to hard wire the device with cat 5. Is it still advisable or advantageous to turn on the wifi radios in the device? tyia
I have it both turned on. And both a fixed IP address set in my router. It is always online since almost a year.
You can keep both but didn’t check how the fail-over works (some apps might have problems in case you different IP).
Anyway, in my case, I keep using ethernet, because Wifi increasing CPU temperature by 1C
How do I turn off WiFi?
Via repeating the Setup, search in the Knowledge base.
But that option using the wepApi playground only is to switch off if you had it configured already.
