Homey pro 2023 does not pr default use ethernet
after i have setup wifi connection it would be nice if homey self change to ethernet when availble :slight_smile:
could this be solved in next firmware ?
That’s a good suggestion, but This is a community forum, you won’t get a response from Athom here.
As far as I know it works that way already since day 1.
But wifi stays active, including it’s own IP, only it is not actively used when ethernet has an active connection.
It’s designed like that to use wifi as a failover network connection.
