New and first time user of Homey (HP23) here! My timeline stopped updating a day after I started using the Homey. Initial update to rc.110 shows, a low battery message on a Hue motion sensor shows. Me leaving and arriving also. But after a day, no more messages on the timeline, for three days now.
A simple test flow to push a msg to the timeline works. But arriving/leaving home, backup completed, and push notifications do not appear on the timeline. Settings are so that they should.
I have all my Timeline settings to “on” but only Presence changes and App updates shows on the timeline. What could be wrong? At least Backup and Flows should appear?
I only know of ‘rate limit’ (with Pro 2019), which resets after 24h or by a system reboot.
But in that case, when you test a flow it shouldn’t work, but it does:
Did you inform Athom in the meantime? Already cut Homey’s power for 15 minutes?
Thanks for the thoughts. I did inform Athom with diagnostic report and more. Will wiat and see. And thanks for clarifying re: push notifications not appearing on timeline; did not know that!
15 minutes power cut seems a lot I may give that a try if situation remains the same.
