The new Philips Hue Bridge
Yes, and that’s true, initially it didn’t work for me either; I just had to go to the device pages for the motion zone and try a repair.
I migrated to the Hue Bridge Pro. Afterwards, all Hue devices were no longer available in Homey Pro. So I deleted the Hue app from Homey Pro and added it again. Then I added all the lights back, and they work. However, the motion detectors aren’t working. In the Hue app on my smartphone, I can see that the motion detectors are working correctly, but unfortunately not in Homey. The sensors aren’t registering any movement. The funny thing is, according to the sensor’s display in Homey, the last readings were taken “56 years ago.” I’ve now tried several times to completely delete the sensors from the Hue Bridge and add them again, then add them back to Homey. It’s not working.
A quick update after two days and several attempts to get the Hue lights and sensors working properly. After numerous restarts and resetting and re-integrating two of the sensors, the sensors eventually worked. However, the joy was short-lived; just a few hours later, the sensors stopped working again with Homey Pro, and the lights had an issue where their status wasn’t displayed correctly in Homey. For example, if the lights were switched off using a button, they were still shown as active in Homey. Eventually, I gave up and integrated the lights and sensors into Homey using Matter. Now all Hue devices are working as expected. This isn’t really a problem, as all the functions are available, but the Bridge Pro has been available for several weeks now, and according to the official Hue-Homey integration, it should also work.
That’s indeed a bit odd, when you didn’t know
Unix time starts at 01-01-1970, 56 y ago
After some time, the new Hue Bridge Pro stops working with Homey Flows. When I run a flow manually or automatically, nothing happens. However, I can still control the Hue devices directly from the Homey app. So the issue is only for flows and Hue-devices. Restarting the Hue app on Homey temporarily fixes the issue, but only for a few hours. Is there a solution for this?
Hello how have you connected the bridge into the homey system, over the official Athom Hue App or directly over Matter?
Hello Effendi68, may i ask you a question, i just start with my homey project, first step hue integration over 60 devices, i could also see many differents between matter and app integration of the devices…what would you finally recommend and why? THX
With the Athom Hue App, the hue bridge hue pro uses wifi
Thx for feedback i will do, but is there a huge benefit between Athom Hue App and Matter integration which i currently don’t see?
I integrated my Hue devices via Matter because the status of the lights wasn’t updating correctly through the Hue integration, and the motion sensors were unusable.
However, I still set up the Hue app in Homey to access the Hue scenes. I find this very convenient, as you can directly access the scenes set up in Hue within a flow. But I handle all direct device control via Matter.
Tom
thx for feedback this would be also an idea, fine! One question please regrading your feedback, with scenes you mean in the Homey Hue app the cards which you use for program a flow yes? Because i read already that it should be possible to use the light modes Scenes inside the original Philips Hue App like for example Night Light or Relaxing or Energy….but this does not work or?
Hello, by scenes I mean the scenes set up in the Philips Hue app. These can be addressed in Homey via a flow.
Here is an example
Hi….thx for your explantation now i understand what you mean! I have decided now to give the Homey Hue App a chance, for me it have definitive both methods different positive and negative facts, over matter you get for sure the better status because when a lamp loose the 230V you see this with the red flag beside the lamp, with the Homey Hue App the light stays ON and you must manually reset them to status OFF….maybe there is anywhere a big benefit in both systems which i currently not see, but aim at the beginning of my Homey journey and aim pritty sure it comes up :slight_smile:
Ok I have forums and still having a difficult time migrating from Hue Bridge V2 to pro. I updated to Pro Bridge by doing the following:
-Disabled Philips Hue App in Homey
-Migrated over to Pro within Hue App on iPhone
-Enabled Philips Hue App in Homey
-clicked + and add Philips Hue device, Lights, but didn’t add any lights. Deselected all
-Tried to repair and used maintenance action and no luck.
What am I missing?
I have tried to rebooting the bridge itself, as well as Hue app in homey and Homey Pro itself.
I had the exact same experience and ended up readding them all as new devices
This keeps me from switching to be honest.
I have approx 75 bulbs, 5 sensors and 6 switches. It took me a couple of hours to make the switch. I’m glad I did as it ultimately simplified my setup, reducing the bridge count from 3 to 1, changing scenes and overall response times were reduced. And I now have access to MotionZones
Has anyone successfully paired IKEA TRÅDFRI drivers with the new Hue Bridge Pro, and then integrated them into Homey?
I’m running into an issue while migrating from two Hue Bridges to one Hue Bridge Pro.
I’ve disabled the Hue app in Homey (on my Google Pixel), did the whole migration of both bridges within the hue app, then went back to Homey and enabled the Hue app. All devices are shown with red triangles and it tells me “Searching for Hue Bridge”.
How can I get all the devices to be recognized? :frowning:
I’m running version 7.3.9 of the Hue app on Homey.
EDIT: when I open one of the devices, go to maintenance and select “Check for Bridge Migration”, it says: “Could not start maintenance action”.
@Doekse quite some people in the past two months with the same error when migrating to Hue Bridge Pro. Any tip on what to do when you get the “Could not start maintenance action” warning?
I feel like it might be useful to have a guide for this because searching through these massive forum threads is not helpful. I was apparently looking at an older thread on this topic, so I wasn’t aware of the button in the maintenance settings. Since I did the full migration already in the Hue App it instructs you to reset your old bridges. I can’t find anywhere that explicitly says you need to have both bridges online to use that feature, but I may not have spent enough time reviewing comments. Philips made the migration impressively seamless and did a great job accounting for edge cases. I know this is a hard challenge to make seamless, but based on the number of comments and threads, it seems like a large portion of your user base is interested in the topic.
