Isnât this already possible? Set it up so that when the water level drops below X, then the pump activates.
âwait untilâ can be very useful to implement timeouts (for which I use the HA-equivalent âwait for triggerâ a lot).
For example, if I donât lock my car when I come home, I get a notification asking if I want to lock it or leave it unlocked. If I donât respond to that question within a certain time (âwait for triggerâ), the car gets locked automatically.
Or: when we wake up, wait for the central heating to turn on and if it does (itâs colder than the target temperature), also turn set the the air conditioner to heating mode so itâll warm up more quickly.
Wait_until(trigger) may be useful, but for me personally it seems quite âoverkillâ in our current purely event orjented system. For me personally it seems the logics may be simpler, if there is just a quick event->response declarations and no need to think, that âsomething inside of event chainâ may just be sleeping/waiting.
Again, this is my personal opinion, but ⌠if there is such card, then itâs must be very complex and include lot of additional conditions - timeout to wait of course, but also possibility to check additionally all the previous chain. Here was the washing machine example - to stop chain and wait until door closed. But what, if the initial start condition changed during the waiting?
Actually, the âwait untilâ seems for me more like an additional flowâs internal timer
Right now most of such tasks are handled by external apps, but those apps/timers are visible globally. May be benefit, may-be unneccessary expose. During âsimple flow timesâ this was feature - possibility to use one multiple flows ( events actually ) to manage timer. With advanced flows, i think, itâs little bit better practice to use timer inside of one (advanced, multi trigger handling)flow.
So⌠actually, i think, this description may mostly cover also Robertâs ideaâŚ
- Activity "Wait ( seconds )
- Activity âCancel wait(local?!? name )â
- Activity âReset wait(local?!? name )â
- Activity âRight now(local?!? name )â ?!?
It can be done much easier.
Take a card that has two inputs. One input is the trigger input that starts the internal timer. The second input needs to trigger before the internal timer runs out (the âwait untilâ part). If so, the card continues. If not, throw a timeout error.
You can implement this with one of the timer apps, but it would be an annoyingly large flow:
- WHEN trigger#1 THEN start timer
- WHEN timer expires THEN throw timeout error
- WHEN trigger#2 AND timer is running THEN stop timer and continue
And while weâre talking about it: the reason why the various timer apps exist is because Homeyâs flow are simply lacking semi-advanced timer functionality that makes a lot of sense to provide out-of-the-box (something like only triggering a flow when a sensor has had a particular value for an X amount of time, so âWHEN the temperature has been >= 20°C for more than 5 minutes THENâŚâ)
Fully agree with reason for timer apps.
But the complecity i described ( my wildest dreams ) is exactly for Your example ![]()
To solve continously and is also now for temperature this is no sufficient to have timeout only. Itâs requires also checking⌠Ok, i can imagine the logic for temperature with only card, You described, but does it seems simple also to Joe, the Average?
- Trigger 1 - if temperature >= 20
- Trigger 2 - if temperature <20
- Timeout 50
- ânormalâ exit to nothing
- âtimeoutâ exit to action
For me seems little bit âupside downâ - but may-be this is my personal problem. The direct actions to manage timer may little bit increase the use-cases. Hmm, for example âto keep the light on when someone is in room - motion-triggerâ. Yes, also solvable with one action card, but quite hard to understand and little bit more hard to realize in flow if lot of events land into the one cardâŚ
Yes, i think, the Turing Machine is already there, and fully functional - right now we are talking about additional libraries for that - so, itâs a question of taste ![]()
I donât necessarily see why this would be difficult? Certainly not more difficult than having to use external apps for timers.
Agreed (or at least its functionality should be built-in, the card itself is perhaps a bit too elaborate).
Ok, sorry, itâs goes OTâŚ
For me and for You - may-be not. But for Joe the Average may be little bit difficult to understand, why âError Exitâ is the normal process flow ![]()
Nice to see a bunch of my questions have been brought up during the latest podcast episode!
@Doekse, @Emile and @martijnpoppen
Big cheers to Martijn. Looked like you are doing podcast for a longer period.
Keep up the good work.
Yeah, heâs a natural ![]()
About Tuya recently retracting API access, crippling the âofficialâ Tuya app:
I wouldnât recommend buying that stuff anyways
Athom has strange ideas of what a âmutually beneficial partnershipâ is ![]()
I believe it was just attempt to âslapâ after âslapâ, yet itâs giant against a kid, unfortunately.
Still I understand this approach (even itâs not exactly diplomacy showcase) but we will probably never learn on legal background on who did what and who break what.
Still, probably there should be more shared on this (even Iâm not fan of CN operated cloud located in US? (because of multiple aspects, including distance, operation, reliability, dependency, bottlenecks etc.) ), what are now the options, as they did not commit on any. And users might feel to be abandoned. But that belongs to the Tuya app thread.
@martijnpoppen thanks for being brave and showcasing another level of community support. Really, hats down, keep what you are doing, for the Community and for Athom.
@Doekse Abe I hope you will keep also this semi-developer podcasts (which are very useful for beginners like me) and that there will be some others great community developers joining you over time. I also like the dashboard news, because it forced me to add one more widget on ISS tracker and this is really nice (design and functionality wise) - kudos to @basvanderploeg
For the future, If I may repeat some âdreamsâ topic :
- Bluetooth - bridge/satellite and stability/reach wise, eg. also Wifi dependencies I shared with you already (that you probably know already yourself) etc.
@Doekse @Emile since you mentioned that âconditionalâ widgets are hard to do, you can take a look at how it works for HA dashboard cards. There it is on a widget/card level and not driven by an automation/flow.
I think you already have the buildings blocks with all the preexisting AND cards, they just would need to be checked every X seconds if the dashboard is visible.
But I would already be happy with the limited functionality of date, time and presence (and maybe device state) which i assume could happen even more realtime.
Hi everyone,
The fifth episode of the Homey Podcast is now live! ![]()
In this final episode of 2024, @Emile and I reflect on an exciting yearârevisiting the features we launched, the announcements we made, and the highlights that defined our journey. We also give you a sneak peek at whatâs on the horizon for Homey in 2025.
Wishing you all a joyful holiday season and a fantastic start to the new year. ![]()
See you in 2025!
P.S. Leave your questions for the next episode in the comments belowâwho knows, we might answer yours! ![]()
Thatâs great once that becomes available.
Will Aqara cameras also be supported then? Currently, they are not.
