Temperature display
I have sauna and Xiaomi temperature sensor inside there. What will be the easiest way to show up the temperature value on my living room? Any small external lcd display or similar supported?
https://lametric.com/
Or use a Bitron unit is a reverse way :slight_smile:
When temp xiaomi change, set the temperature at the Bitron. Use the Tag for the value and it is fine :slight_smile:
Should work with a different thermostat as well.
Cheap an effective way i found is use Oregon scientific devices, they pair well and display temperature
THGR 122 , 810 and equivalents
I use the Aqara temp sensors only in places where i don’t need to read off the temperature
In a sauna ? The sensor works only till 60° ?
I’m searching for a sauna temperature sensor but you need at least 85 - 100°C max I think ?
No ?
Measurement range: from -55°C to 125°C
Homey App:
