Temperature between?
is there a option to trigger something if the temperature is between two setpoints on when temp is +10 and turns off at +5 then on again when +5 again and off if higher then +10?
Not that I know of.
But it’s pretty easy with these two triggers:
When
-temperature becomes greater less than 5
Then
-on
When
-temperature becomes greater than 10
Then
-off
When the temperature has been over +10, it first has to drop below +5, before flow 1 gets triggered;
And then, when the temperature passes +10 again, flow 2 gets triggered.
You can use Variables, with trigger points.
temp_over_5 - Yes/No
temp_over_10 - Yes/No
No/No temp is bellow 5
Yes/No temp is between 5 and 10
Yes/Yes temp is above 10
I try to do this with humidity
When humidity drops below 45% put the humidifier on
When humidity exeeds 60% turn of.
The idea is that it needs to wait till the first threshold is met and then put the humidifier back on
I feel with your solution it would start again when 59% humidity is reached and turned back on of with 60%
I made a sloppy copy/paste mistake, as I now discovered. I’ve adjusted my post.
Thanks, that makes sense!
