I want a notification or trigger at a specific temperature or wattage on solar panel
I want to set a temperature at which a notification or trigger is sent/activated. E.g when temperature goes below 7°C in my house at winter. I can only find the possibility to get a notification/trigger every time the temperature changes. And this happens often!
Use the “AND” column!
IF temperature changes
AND measured temperature is below 7 degrees (use a tag)
THEN send push message
Problem solved! Thank you.
