Best way to switch device based on multiple (depending) rules
I am strugling with my flows to to switch on a device (in my case a fan but could be any device).
The problem is I have multiple rules that are sometimes even dependend.
Problem:
Determine the correct trigger to switch On the fan
Determine the correct trigger to switch Off the fan
Rules
The ON rules:
  • when the CO2 level > “extremely high” the fan should always go on
  • when the CO2 level > “high” the fan should go on
  • the fan should not go on when the outside temperature is > 20. (Except when CO2 > extremely high)
  • the fan should go on when outside temp < inside temp AND expected temp the next day os >19degrees (cooling down in summer)
  • the fan should not go on when inside temp < 14 (prevent going below dew point)
THE off Rules
  • when the CO2 level > “extremely high” the fan should not turn off
  • when CO2 < “normal” the fan should go off
  • when the inside temp < outside temp AND the expected temp is below 19 the fan should go off
Probably more rules to Add.
Making a lot of seperate flow could become very complex.
I was thinking about the bayesian probability
Any other suggestions???
Nice puzzling again! Not easy to keep it simple.
I think this comes close, FKey…
- Flow F1-5 (CO2 level > “extremely high”)
If..
CO2 level changed
And..
  [CO2 level] > "extremely high"
Then..
Turn fan on
  Else..
  Start flow F5-5 (Fan Off if CO2 level < "normal")
- Flow F2-5 (CO2 level > “high”)
If..
CO2 level changed
And..
  [CO2 level] > "high"
And..
  [outside temp] =< 20
And..
  [inside temp] > 14
Then..
Turn fan on
  Else..
- Flow F3-5 (CO2 level < “normal”)
If..
CO2 level changed
And..
  [CO2 level] < "normal"
Then..
- Flow F4-5 (Outside temp < Inside temp)
If..
[Outside temp] changed
And..
  [Outside temp] < [Inside temp]
And..
  [Expected temp the next day] > 19
And..
  [Inside temp] > 14
Then..
Turn fan on
  Else..
- Flow F5-5 (Fan Off if CO2 level < "normal")
If..
This flow is started
  And..
Then..
Turn fan off
