Since the last update, I have lost my connection with Somfy.
I have io shutters, Tahoma box ( bought especially to use with Homey Pro app)
I reinstalled the app on my Homey, tried adding device Tahome/Connexoon, logging in using the correct email and PW and got the timeout of 10000ms every time. I then always got the blocked for xxx time because too many simple logins.
I called Somfy and they did not see anything strange on their side. I was always able to use the Somfy app to open the blinds.
I then rested the Taboma box. created a new account on it with new email adress and name and logged in the Somfy app. All worked fine. So a complete fresh start.
I again tried the Homey app and a few days ago got the 401 warning leaving me 24 hours blocked. and now a few days later, again the Timeout of 10000ms
The way I work is using the Homey app, add device, search for the Tahome/Connexoon. There they ask me my login an PW (which I am 100% sure thay are correct since I use them in the Somfy app) and I receive the Timeout.
I then try going to the app settings without local key and in the Somfy app just give in my Email an PW and then I get the error: Aborted.
In the information log, I see that mDNS Found a local bridge with an ip address, port. then as source Local login, it says Missing credentials.
I also tried using a local token, that I just created in the Somfy app under developper mode, copied the token and filled in into the field and still no connection…
I am really out of inspiration what to do next. Please help me…
“time”: “2025-12-30T07:32:01.996Z”,
“elapsed”: 0.322,
“source”: “mDNS Found a local bridge”,
“data”: “{
“pin”: “####-####-####”,
“address”: “192.168.0.15”,
“port”: 8443,
“api_version”: “1”,
“fw_version”: “2025.5.5-9”
“time”: “2025-12-30T07:32:01.999Z”,
“elapsed”: 0.003,
“source”: “Local login”,
“data”: “Missing credentials”
“time”: “2025-12-30T07:35:16.026Z”,
“elapsed”: 194.027,
“source”: “Tahoma Cloud Login for local connection”,
“data”: “Error: timeout of 10000ms exceeded”
“time”: “2025-12-30T07:35:16.031Z”,
“elapsed”: 0.005,
“source”: “Tahoma Local Login”,
“data”: “{
“message”: “Failed to get Local Token”,
“stack”: “timeout of 10000ms exceeded”
“time”: “2025-12-30T07:35:16.036Z”,
“elapsed”: 0.005,
“source”: “No local Bearer token”,
“data”: “”
“time”: “2025-12-30T07:35:22.111Z”,
“elapsed”: 6.075,
“source”: “Tahoma Cloud Login for OAuth connection”,
“time”: “2025-12-30T07:35:22.115Z”,
“elapsed”: 0.004,
“source”: “Login OAuth”,
“time”: “2025-12-30T07:35:27.155Z”,
“elapsed”: 5.04,
“source”: “Tahoma Cloud Login for simple connection”,
“time”: “2025-12-30T07:38:21.646Z”,
“elapsed”: 174.491,
“source”: “Using provided local token”,
“data”: “”
“time”: “2025-12-30T07:39:34.333Z”,
“elapsed”: 72.687,
“source”: “getLocalTokens failed”,
“data”: “Not logged in yet”
“time”: “2025-12-30T07:40:07.043Z”,
“elapsed”: 32.71,
“time”: “2025-12-30T07:40:07.047Z”,
“elapsed”: 0.004,
“data”: “{
“time”: “2025-12-30T07:40:07.051Z”,
“elapsed”: 0.004,
“data”: “”
“time”: “2025-12-30T07:40:13.109Z”,
“elapsed”: 6.058,
“time”: “2025-12-30T07:40:13.112Z”,
“elapsed”: 0.003,
“time”: “2025-12-30T07:40:18.139Z”,
“elapsed”: 5.027,
“time”: “2025-12-30T07:40:37.816Z”,
“elapsed”: 19.677,
“data”: “{
“stack”: “Cannot read properties of undefined (reading ‘code’)”
“time”: “2025-12-30T07:40:37.817Z”,
“elapsed”: 0.001,
“data”: “”
“time”: “2025-12-30T07:40:38.821Z”,
“elapsed”: 1.004,
“data”: “Please leave 1 minutes between cloud login attempts, last Login time: 2025-12-30T07:41:08.059Z”
