Impossible to connect my tahoma with Home bridge. i have error message : “blocked for 80456.23100018501s”
Thank you
Thank you
Did you make too many failed login attempts? Maybe you just need to wait a few hours. 80456 s is approximately 22 hours, so just wait a day and try again
Judging by the bridge being mentioned, I think OP is using Homey Cloud, and in the past there have been issues with other brands rate-limiting requests coming from Athom cloud servers. So that could also be the issue.
Maybe another Homey Cloud user made too many failed login attempts then. So the only thing you can do is wait approximately 22 hours before trying again
I have the same issue. Blocked for roughly 24 hours. So I’ve disabled the app for about 36 hours, and just reconnected. Now I received again a 24 hour block. I have the Homey Pro 2023, updated to the latest version.
Only thing I find odd now, is that the Somfy app says the 4.0.124 version of the app is the latest, but the change log is already 4.0.144. Anybody know what’s going on here?
The 4.0.145 is test version
