I’m rather new in making flows, but have experience of PLC-programming.
A difference that I have noticed is that a condition have to have a trigger(become a value or change). Rather often I want to have a condition that for example is IF ? is larger than ? then…, but instead I have use When ? is larger than ? then…. The difference will be that if the condition has already been met, then the condition will not go through.
Is there any way to make such conditions?
I have also noticed that if I have an AND-condition which will be fulfilled, but after a while looses the condition(the AND-condition is no longer fulfilled), the condition still continues to work.
For example I have a condition for a maximum time. If the condition is valid for 60 minutes it will stop the controlled device.
IF temperature is larger than 30 degrees the FAN will start
IF the FAN is ON AND the Temperature is less than 20 degrees the FAN will stop
IF the Fan is ON AND the Temperature is more than 20 degrees it starts an DELAY for 60 minutes
IF the DELAY reaches 60 minutes the FAN will stop, regardless what the temperature is
but I have noticed that even if the Temperature becomes less than 20 degrees before the DELAY reaches 60 minutes, the DELAY continues to count. The FAN will stop, but if the temperature reaches more than 30 degrees and starts the FAN again within the 60 minutes the FAN will be stopped when the DELAY reaches 60 minutes and it could be after 5 minutes after the FAN has been started again, depending how long it takes to reach 30 degrees again during the DELAY is counting.
I hope you understand what I mean. If the Flow loses its condition, I want the Flow/Condition to be interrupted.
